mand p w****ers
WelshD1K
mand p w****ers
buy a chain and sprocket set state that the bike is a 89 h2 import get home strip the chain etc off. put new one on and WTF its too long. so thats £78 for a chain and sprocket set . ring them up and they tell me i can have it replace yay/ then i say what about the split link the new one is twisted from removing it then the cunts tell me i have to pay for a new one??? f*** OFF it even says on the bos only use the split link once ...
FFS
and teh whole all zxr's are listed with us with 110 link chains well why f*** does everywhere else says 108 link w****ers
FFS
Re: mand p w****ers
ERRRRRRRRRRRRRRRR....................... just cut it to length
Every chain I buy comes as a standard length that needs cut................I though they were all like that
Re: mand p w****ers
interesting.....i've always thought the zxr400 had a chain of 520 x 110 links. as per the Manual, after reading this post i did a bit of searching on here and general feeling is 110 links. I also checked out the German manual which surprisingly states for an L model .....108 Links.
- Scott221
- Restricted
- My Bike: ZXR400 L9
Re: mand p w****ers
cargo wrote:ERRRRRRRRRRRRRRRR....................... just cut it to length
+1
- crushedlizard
- My Bike: ZXR400 L2
Re: mand p w****ers
What sprockets are you running? I bought a 110 recently and it fitted fine.
Mind you I have an L2 and I'm on 14/47 so had to move the wheel quite far forward to fit round so would have been perfect length for 15/45.
Not being harsh but surely you could see it was to big before you punched the links?
That said, is the H2's swingarm shorter than the L? That could explain the 108. In that case, it's their error.
Re: mand p w****ers
ahhh so H model is 108 links, L model is either 108 or 110 links depending which country.
WelshD1K
Re: mand p w****ers
why should i have to cut a chain to lenght when every web site states a h model runs a 108 link
and prockest is 15/45 because they didnt have any other sizes i did want to down gear it
- crushedlizard
Re: mand p w****ers
Yeah if H's do use a 108, that's their fault. You'd think they'd swap it as a good well gesture. Keep hassling them.
But, if worse comes to worst, you can cut it down. Would be even more annoying if you were 2 links short! lol
Re: mand p w****ers
Reading the first post again
WTF are you doing using a chain with a split link................................no thank you sir keep yer chain and buy a decent one with a rivet link
Re: mand p w****ers
+1cargo wrote:Reading the first post again
- crushedlizard
Re: mand p w****ers
lol I thought he meant rivet, hence he mangled it taking it off!cargo wrote:Reading the first post again
Jesus, yeah don't use a crappy bicycle link!
WelshD1K
Re: mand p w****ers
crushedlizard wrote:lol I thought he meant rivet, hence he mangled it taking it off!cargo wrote:Reading the first post again
whats wrong with split links? its some special sealing one that breaks if u try and take it off
Re: mand p w****ers
I think the problem with them is, if you give it handful the chain will stretch and it will pop right off. With a rivet chain link that wont happen. As someone said they are for bicyles really, not for 140mph bikes.
