will this fit
Chris1984
- My Bike: zxr 400
will this fit
http://cgi.ebay.co.uk/KAWASAKI-ZXR400-L ... 9|294%3A50 will this fit my 1996 model
Re: will this fit
Only if you have the holes drilled into the plastics, as well as the sub frame having the necessary bolt holes for it to bolt into. You will have to check.
Chris1984
- My Bike: zxr 400
Re: will this fit
Yeah i have the holes looks like one used to be there.RedexRobB wrote:Only if you have the holes drilled into the plastics, as well as the sub frame having the necessary bolt holes for it to bolt into. You will have to check.
stug
- My Bike: Yamaha R1
Re: will this fit
The subframe part that the grabrail bolts to is a seperate part which if not already on the bike can be bought from Kawasaki for around £35.
I bought this for my wifes bike as I got hold of L9 plastics and spoiler but the subframe did not have the mounts to bolt it to.
I think this is only fitted to L9 models only.
Re: will this fit
They were fitted from 95/96 onwards, so thatll be L5 - L9
