Hi,
as the title said ; Think i blew the headgasket on my ZXR440 (59mm bore) Anybody knows where i can order one?
Thanks,
Joris (Belgium)
headgasket 59mm needed
Re: headgasket 59mm needed
TTS sell the big bore kits so i guess they would be the best people to source you a proper head gasket
http://www.tts-performance.co.uk/
- My Bike: zxr440
Thanks but i've tried to contact them a few times via e-mail (only answer inquiries via e-mail if from abroad as i've discovered on their site), looks like they're not interested in selling across the water cause i've been getting zilch-tuut-replies
- My Bike: zxr400sp race bike
hi, as far as i know there is no head gasket available for the big bore engine, the normal tactic (including TTS) is to file out a standard gasket to fit. if you have a dremel or somthing along those lines it doesn't take long.
if you should be lucky enough to find the genuine kawasaki kit head gasket, then these have a little more scope for filing out as the compresion area is further out. very hard to find now though.
good luck.
good luck.
