Suspension and brakes
ZX-6R forks - fit into ZXR yokes. (how does this affect the wheel and brakes?)
BigB wrote:ok please can you confirm if these will fit the H model
i know i know, im on an H model, but a lot of info seems to be for the L models - i assume a lot of the threads that are made asking bout which part fits which are for L models only ... feel a bit left out with my H lol
Mori Man wrote:ZX6-R used conventional forks initially
ZX636 uses USDs with radial calipers
NO - they will not directly fit H triples , however if you reem out the lower clamp by half a mm they will. Buy a honing stone set and get busy with your drill
MM!
ZX6R F1 & 2, and ZZR600D calipers bolt straight on.
GSX-R 6 pot callipers - fit ZXR forks. (Anyone got any detail on what mods are required? Which gixxers, etc)
banner001 wrote:with 10 minutes of "dremmeling" a GSXR 1000 K1 rear caliper fits.
viewtopic.php?f=121&t=13834
Perilous wrote:Also ZX6R F1 & 2. ZZR600D calipers go straight on. I've found the ZZR ones quite easy to get hold of in reasonable condition.
RedexRobB wrote:Levers also interchange between models. I remember when i bought a lever from ebay and checked with kawasaki that it fit, it would also go on a GPZ and an ER5. There were other but i forgets.
Rear calipers also swap between models im sure, as well as front brake calipers, they look different but they fit the same, the ZXR750 caliper fits too.
Footpegs, they are used on loads of other models, got the same on my ZX7R, had em also on my old GPX 250.
Feetrest hangers also swap between L and H model, as with calipers the look different but fit the same.
Rear shocks swap too!
The rear disks are a common part too for kawasaki. Again had the same disk on my GPX 250 and seen them on various other kwaks.
Fuel caps also swap, same on my ZX7, GPX 250, ER5 etc...
cant think of much more
MillaMeter wrote: Aparrently CBR900 Fireblade 4 pot nissins are a straight swap with lil mods needed, I.E. 10mm to 8mm spacers.
Regards
Rich
bendog66 wrote:I noticed someone was asking about Pazzo levers?
Well, a GSXR600 (can't remember what year) front brake lever fits straight on, but you'd need to change the clutch lever mounting. I used a ZX636r one for this, but i guesss any zx6 one would fit. Could probably use the matching gsxr600 one and get them a bit cheaper by buying a matched pair.
And regards to the GSXR calipers, it's the 1000cc K1 and K2 models. I know coz i've got them on mine. You'll need a matching master cylinder mind. And you need to use spacers, but thats all the mods you need to do.
masterofinsanity wrote:Front brake pads for H models
Kawasaki KR-1S (KR 250 C2/C3) 90-92
Kawasaki ZXR 400 H1/H2 89-90
Kawasaki ZXR 400 R (ZX 400 J2) 90
Kawasaki ZXR 400 R (ZX 400 M1-M4) 91-94
Kawasaki ZXR 400 R (ZXR 400 J1) 89
Kawasaki ZZ-R 400(ZX 400 K1/K2/K3) 90-92
Kawasaki ZZ-R 400 (ZX 400 N1-N7) 93-99
Kawasaki ZX-6R (ZX 600 F1-F3) 95-97
Kawasaki ZZR 600 (ZX 600 D1-D3) 90-93
Kawasaki ZZR 600 (ZX 600 E1-E12) 93-04
Kawasaki ZXR 750 H1/H2 89-90
Kawasaki ZXR 750 J1/J2 91-92
Kawasaki ZXR 750 K1/K2 91-92
Kawasaki ZXR 750 L1-L3 93-95
Kawasaki ZXR 750 M1/M2 93-94
Kawasaki GPZ 900 R A7-A11 90-98
Kawasaki ZX9R (ZX 900 B1/B2) 94-95
Kawasaki ZR 1100 A1-A4 Zephyr 91-95
Kawasaki ZZR 1100 (ZX 1100 C1-C3) 90-92
Kawasaki ZZR 1100 (ZX 1100 D1-D9) 93-01
Kawasaki ZZR 1200 C1/C2/C3 02-04
Kawasaki VN 2000 A1 04
Suzuki RG 125 FUN/FUP Gamma 92-94
Suzuki RG 125 FUR Gamma 94-96
Suzuki GSXR 250 RK (GJ73A) 89
Suzuki RGV 250 J/K/L/M 88-91
Suzuki RGV 250 N/P/R/S 92-95
Suzuki TV 250 J/K/AK/L(VJ21A)Wolf 88-90
Suzuki SG 350 N Goose 92
Suzuki GSF 400 K/NK/Z/VM/VZM/P/NP/VP/VZP/VR Bandit(GK75A)(import) 89-94
Suzuki GSF 400 V/VS/V-V/VZ-V Bandit (GK7AA) 95-97
Suzuki GSX 400 SSN (GK77A) Katana 92
Suzuki GSXR 400 J/RR/RAK (GK73A) 88-90
Suzuki GSXR 600 K1/K2/K3/ZK3 01-03
Suzuki GSXR 600 V/W/X/Y 97-00
Suzuki GSXR 750 Y/K1/K2/K3 00-03
Suzuki TL 1000 SK1 01-02
Suzuki TL 1000 SV/SW 97-98
Suzuki TL 1000 SX/SY 98-00
Big Hoddie wrote:K2 gixer 6 calipers
CaNsA wrote:zx6r f1 rear shock.shave a couple of mm from either side the top fixing hole carrier bit.
Bodywork:
L Model Mirrors - common with GPz500S (D)
Fuel Filler Cap - common with GPz500S, ZX-7R, etc
Scott221 wrote:ZX6rr mirrors will fit with slight modification.Cut off the stems and drill some new wholes. Works fine.
Lights:SOILZX wrote:Mirrors from y reg zx6r (j2 model?) fit straight onto l model
L Model Tail light lens - common with GPz500S (D), ZXR750 (L)
Please contribute below, I'll try to edit this post to include everything that gets posted. Maybe when we've collected a bit of info Baz could create a page for it on the main site? Also feel free to post corrections or more detail on anything which has already been included.
Misc:
Speedo Drive - ZZR (what size?) one fits.
Haggis wrote:Radiator cap from the ZRX1200 defo fits and I've been told the ZX6R later models.
masterofinsanity wrote:pretty sure the zxr750 L model fusebox is the same, so is the chain guard and rear light & indicators.
grey zxr400l wrote:front# 41073-1497-x4 black is same as ZX-6R 1995-97/ also fork seals for 41mm Showa usd are interchangeable,T-stat,speedO cable,gas filter,fuel pump-#49040-1057 same as 1993-2001 ZX6-NOT 'r' model,outer fork bushings-Not the inners. WHAT does the rear wheel #41073-1472 interchange with???
RedexRobB wrote:yep rearsets swap from L to H although they are different shapes..
reds wrote:well just got one - £10 buy it now ! turns out there very interchangeable - for future reference if anyone needs it :
RECTIFIER MODEL NUMBER: KAWASAKI - 21066-1101, SH658-12
80MM L X 90MM W X 28MM H; HOLE DISTANCE 66.8MM; 3 PHASE, W/SENSOR
USED ON;
GPZ 600 R
VN 700 A1 VULCAN (85)
VN 750 A2-A9 VULCAN (86-93)
VN 1500 VULCAN 88 A1-A5 (87-91)
VN 1500 VULCAN 88 SE B1-B4 (87-90)
VN 1500 VULCAN (87-01)
ZL 600 A1-A2 ELIMINATOR (86-87)
ZN 700 A1-A2 LTD (84-85)
ZN 1100 B1-B2 LTD (84-85)
ZR 750 C1-C3 (91-93)
ZX 600 A1-A3 NINJA 600R (85-87)
ZX 600 C1-C6 NINJA 600R (88-93)
ZX 600 D1 NINJA ZX-6 (90)
ZXR 400
ZR 550 ZEPHYR (00-01)
ZR 750 ZEPHYR (91)
ZR 1100 ZEPHYR (93)
MillaMeter wrote:Hi,
Just to let you guys know, that the ZZR250 fusebox also fits the ZXR400, I can confirm this as I am actually using 1 off my mate's bike lol.Rich
zxr400rider wrote:just a quickie for anyone with an h model l throttle cables dont work properly they are to short if like me you couldnt be arsed to ring around and looked on ebay, a zxr750 h model throttle cable fits PERFECTLY i got one on my bike now i also have a zzr600 rectifier, zxr750 mirrors and a zxr750 end can with a very small adjustment to the holes on the link pipe it fits, theres more available second hand aswell. just a shame the downpipes wouldnt
Engine:
zub wrote:i've heard a kawasaki ZL400 engine is practically the same as a zxr400 engine and so is the gpz400 ninja.
gavinfdavies wrote:sprockets:
std front sprockets is 15 tht. gpz500s std srocket is exactly the same fitment, but 16 tooth...
this makes the zxr a little more of a tourer did i say tourer? i meant endurance racer ahem!
going up one on the front drops the revs by about 7%, so 100mph drops to 9300rpm.
on the cruise i get about 45mpg from mine (and i cruise at 100mph ish, 90 is only used when i'm on reserve, and boy does it seem slow!)
I've got a gpz500s (d3) at home so i will keep an eye out for what parts can be swapped over. I suspect rear sprockets can be changed too.
