zxr at the butchers!
Daniel.p
- My Bike: Zxr400 93
finally got round to doing my cam chain at the arm and leg of £400 got to the garage and the guy couldnt believe it hadnt blow up the way the chain was rattling. how long does a new cam chain last? im egtting new chain 3 new blades and new tensioner
Ride it like you stole it
Re: zxr at the butchers!
huge windows....................seen ya coming
£400
£400
Daniel.p
Cheapest quote for 40 miles 160 for parts 240 labour its at a genuine kawasaki centre i suppose so nice long gaurantee!
Hoof ! You could have almost flown me over & I would have done it for you at that price
Camchain life is a bit like " How long is a piece of string "
Imersed in clean oil and not stressed it should really go for ever , but considering time and fatique you should change every 10yrs regardless.
I am fairly heavy handed with my bikes
an average around the 30K miles for a chain , tensioner blades never look to bad but I change the whole lot including the tensioner as a complete job. A bit like changing the cam belt on your car - false economy not to replace the pully on it ! Dropped valves in a car are not nice !!
So it's good to see them doing the same thing
Chances of parts failing these days is very thin so unless your doing over 30K miles a year your guarentee is for labour only.
Have they said they are going to check/adjust shims too ? Having the rocker cover off to do this job your best getting this seen to as well.
240 labour equates to 10hrs work unless they are charging double that so your still at 5hrs which is more than plenty for a chain swap on these bikes.
Parts, I would use and cost here, Camchain , 3 blades , 2 x O rings , tensioner body & spring = 130.12 GBP
They would buy that lot at trade for a max of 123.60 GBP cause when you add the standard 30% retail it jumps to 168.68 - most likely they are getting it cheaper and are adding upto 50%
Be good if you list all the new parts exactly and someone prices else where as a comparison but looks to me they are OK on parts but hitting you with labour charge.
MM!
PS. I have had my GPz6 sounding like a skeleton having a skunk in a biscuit tin before and it still ran fine - what can happen is the slack gets caught up at the bottom end and you seize the cams or the chain jumps a tooth or two on the sprockets and you bend valves - engine blowing up mmmmmmmmmm.
MM!
+1
wot he says
I've had a tensioner blade fail on one of my engines and seen a couple broken on other peoples bike.................mostly delaminating but mine actually broke.
I wasnt even using it at the time A mate had borrowed my spare bike.............. it was running fine untill the ignition pick up got damaged by the tensioner and the bike stopped.....................no valve or top end damage at all.........new chain new tensioner new tensioner blade and new ignition rotor new pick up and it was up and running again
wot he says
Daniel.p
Yeh i imagine theyll do my shims for the price im paying for labour i get that bike back and hear any sound apart from the humming of the can ill be straight back in there on the + side they get the new 2011 zx in there so taking that out for a spin
Heres pics from this week it has 3 different colour schemes
