mark400 wrote:@mistgiri
135KG is very light !
Yes thanks
i've some projects to reduce more but step by step!
So the bloke that told me the SP gearbox's were different between SP models was indeed correct. It would be interesting to try an L SP and an H1 Sp gearbox back.cargo wrote:I've had a text on this SP gearbox topic
H1 SP CR gearbox has a very tall first gear H2 less so and L less so again but still taller than the regular gearbox
How about just buy the gears you need and re-gear your existing box ?mistigri wrote:I'm still SEARCHING :smt013 HELP
Mori Man wrote:How about just buy the gears you need and re-gear your existing box ?mistigri wrote:I'm still SEARCHING :smt013 HELP
You'll be stripping the engine to but a complete box in anyway so just pay for what you need and you fitting new components.
Or,
I can buy you an SP engine, strip it down and send the goodies - been done for several forum users already. Much of the J2 box is same as the M but 4 parts are no longer available !
Really? i just need a gearbox but i don't know anybody which can built a box in sp quality!!??
(i have already sp cams but the sp pistons are also different an interrest me
Do you have a nest in your country![]()
I 'd be happy finding one gearbox.
MM!
If it's a J2 that's a keepermistigri wrote:Can i mount a H sp gearbox in an L motor?
Moriman, u have any SP parts available ?Mori Man wrote:If it's a J2 that's a keepermistigri wrote:Can i mount a H sp gearbox in an L motor?The J1 isn't as good but all gearboxes are interchangeable.
You can look at the online fiche I posted up and get complete listings of the part numbers of each box , from there identify what gears and shaft is needed to modify your particular gearbox to M spec if that's the gearing your looking for.
I will use J2 gearing in my H chassis.
MM!
