Problem
wildkid
My Bike: ZXR400L 99reg
Problem
Post by wildkid »
When i let my bike idle, my right indicator is fine, but my left flashes a lot slower and sometimes even stops flashing and is just a constant light?
also when i try starting my bike from hot, it sounds as if the battery is dead/ struggling but as soon as its cold, it just fires back up straight away no problems?
Daniel.p
My Bike: Zxr400 93
Re: Problem
Post by Daniel.p »
The problem starting is kind of normal as most of us have the hot start issue theres a thread dedicated to it the indicator is mayby a bad connection or your relay could be naff
Ride it like you stole it
Re: Problem
Indicator sounds like its a dodgy contact somewhere. Check the bullet connectors to make sure thye are pressed together fully.
Starting issue does sound like its the hot starting problems that ZXRs are famous for.
viewtopic.php?f=166&t=3391
