bit of an issue and can't get my head round it.
every time i come to a stand still, the bike revs on its own to 3,000 rpm and the only way i can stop it doing this is if i slip the clutch a little at the lights to get it idling normally, it eventually revs back up to 3k again if stood longer.
she's due an oil change and i need to replace the rocker cover gasket, the throttle cables are like new and arent snagging on anything, choke cable is also fine
the only thing i can think of it being are the clutch springs causing clutch drag - but the bike doesn't pull at stand still with it in gear and clutch disengaged
...help
						bike revving
- R P Corse
 - CBT slow
 - My Bike: ZXR400 H1
Re: bike revving
could be the carb rubbers leaking, spray some carb cleaner around where they join the head whilst running and see if the revs rise.
						- R P Corse
 - CBT slow
Re: bike revving
yup got it sorted now, carb inlets are perished/perishing, no biggy, nearly a 23yr old bike lol
cheers MOI
						cheers MOI
