Page 2 of 2
Re: HID Xenon bulb conversion... 300% brighter!
Posted: Sun Sep 22, 2013 8:59 pm
by tink
Very nice might get a set of them
Posted: Mon Sep 23, 2013 1:33 pm
by Songshan
Took it out for a spin last night. There's definitely a difference. Although I think I'm stuck on full beam at the mo so I've angled the beam downwards to stop blinding anyone. Think my issue with the low beam is a fuse. Now looking for this glass fuse on the left hand side?? Anyone any ideas where that is?
Posted: Wed Sep 25, 2013 2:35 pm
by Songshan
Hey,
Ok not found the fuse but haven't looked yet. Spoke to a nice lady at Hids4u. The piece with the two switches works best with bikes so what I have installed is correct, the small box with the double leds (part of the h4 bike kit) needs to be swapped for the double switches one.The switches should both be either in the on or off position and not one of each. Fine on that count.
The second small connector on the same output as the three pronged bulb plug is a bit stiff so need to make sure it's properly connected. Also i need to check that the bulb physically moves in and out whilst switching from low to full beam. That's how it works apparently. Will check this all out and let you know.
My pass light works with the lights off, with the park light on, but lights on full gives me full beam rather than dipped. Could that be a fuse?
Not sure why the switches lead doesn't come with the slimline ballast kit then? That would save 40£ odd.
Posted: Sun Sep 29, 2013 7:29 pm
by Songshan
K wasn't the fuse. The bulb was faulty. Took it off the mounting and it wasn't moving. Replaced it with the other one from the other kit, hey presto the bulb moves and I now have low beam/high beam. Boom!
I would definitely recommend this kit. If, like me, you only have 1 front light cluster, phone hids4u and ask for the slim line balast kit with the double switch lead rather than the box with the two red LEDs on it. About £40 in total and I suppose double that for a twin light. Happy that the winter riding is going to be much safer now.
Posted: Tue Oct 01, 2013 8:57 pm
by Songshan
Blasted up to Orpington from Bristol last night. Wicked spread of light on low beam, and a nice trail of melted retina behind me on high beam, well at least from the odd friendly flash to drivers to ask politely to get out the way. Happy days! Best mod out there for my sh***y zxr lights.
Posted: Fri Dec 08, 2017 1:20 pm
by bumble72
gavinfdavies wrote: Sat Dec 04, 2010 12:18 am
Result...
The yellow one is an Osram 40%+ H4 bulb (55/60W) whilst the white one is the 35/35w HID bulb. When riding you can't even see where the H4 is illuminating, because the HID is just so damn good!
That,s a hell of difference. And a very nice explanation. Cheers. I guess you wouldn't have a pre and post fitting photo of illumination on the road? If not have you found a big difference in night riding with the HIDs.
You wouldnt have tried led vs hid would you? And which did u find better for night riding? And fitting?
Posted: Fri Dec 08, 2017 1:36 pm
by bumble72
Songshan wrote: Tue Oct 01, 2013 8:57 pm
That's good to know.
Cheers Song.
Have you tried led lamps at all? How do they compare to HID?
Declan
