well whats it doing? does it fire up and hold idle fine, how does it run to ~5k rpm, and after that?adamhearn wrote:Good write up.
I've stripped my carbs 3-4 times and my bike is still running badly
How to strip and clean your carbs
Re: How to strip and clean your carbs
Ridiculously hard to find JIS screwdrivers for under £25...but ive managed to find out that Tamiya screwdrivers are JIS headed...so you can use those and they are much more plentiful/cheaper.
- M0rd3kaI
- My Bike: 1996 Kawasaki ZXR-400
Struggled my backside off to remove the carburettors after various sources told me to clean those buggers... just could not figure out how in heavens name you remove the carbs, but with one of your pics I saw there are no screws attaching the carbs to the engine directly, so I went hunting for clamps of sort... Thanks I don't think I would have found them so easily had it not been for this tutorial. Will test it today and see how much of a muckup I made.
I got bored on my ZXR-400 for a while on the straights...
Until I realised the speedo was reading on the better side of the 180 cut-off...
- My Bike: ZXR 400 L9
banner001 wrote:Ridiculously hard to find JIS screwdrivers for under £25...but ive managed to find out that Tamiya screwdrivers are JIS headed...so you can use those and they are much more plentiful/cheaper.
The difficult bit for me was finding a flathead screwdriver that wasnt too bit to fit inside the pilot air jet screw hole, yet had a big enough head to get decent traction. In the end I gave up and just gave it a good flushing with carb cleaner (and my eyeball incidentally
- Restricted
- My Bike: zxr 400 l6
I had an old old screwdriver that was the right diameter and just reshaped it on the bench grinder, also im going to go to a shop in town and see if I can get some shouldered Allen headed bolts for the top of the carbs, rather than pissing about with awkward screwdrivers, already changed the float bowl bolts and it is much easier
- My Bike: Yamaha R1
Nice right up, think i'm going to need this a reference over the next week or so
- My Bike: ZXR400 L5
Hey banner001, what do you think of leaving the carbs (after removing all rubber and plastic parts) for one day in acetone or paint thinner and after that clean them with compressed air? I don't have access to a sonication bath so I'm try to find some good alternatives. Thank you!
as long as there is only metal in there shouldnt do anything bad to the carbs, make sure they are fully submerged throughout
- My Bike: ZXR 400 L4
Brilliant write up & just what I need to try get mine running! I know its a few years ago but thanks for doing this
no worries, always remember rule #1 - don't be a twunt
- My Bike: 1991 ZXR400 L2
Great how to, I didn't realise about the smaller fuel filter, couldn't believe how badly blocked they were, many thanks for this.
Rob
Rob
Just stripped & cleaned my carbs with the help of Banners writeup! Now fitted but waiting on my carb balancers to arrive before I make a judgement on whether they are sorted or not
always glad to be of service
- My Bike: Suzuki RGV250p
Does anybody have any tips for removing the brass fuel filters/float seats? Mine just will not budge with pliers!
Kev
Kev
Got them out. In case you are in the same situation and yours will absolutely not move with pliers, I used a bolt extractor. I had replacements so wasn't worried about chewing up the originals.
Kev
Kev
