Page 3 of 3
Re: H1 with ZX4 Engine
Posted: Fri Nov 08, 2013 11:38 pm
by kawazonkey
Cheers for the info, found it on ebay and ordered one!
Posted: Wed Nov 13, 2013 9:11 am
by ross46
Another paint question! How much did you use? How many cans? And did you look at the 1pk lacquer they do aswell? I've got a compressor and paint gun but thinking that I can spray quickly with the can to get looking ok then do it properly later
Posted: Tue Jan 21, 2014 10:42 pm
by ZX4R-F3
I think it worked out about two tins per panel, i use simoniz clear lacquer nice to work with and doesn't take an age to harden. i may invest in a compressor one day would save a lot of time and effort.
Posted: Sun Jan 26, 2014 10:07 pm
by ChristoT
Just out of curiosity, where did you get your ZX4 engine? Mine's just failed (how dramatically, I won't know til I strip it), but chances are it's dropped a sleeve. Nicht gut. Where did you find spares for the engine?
Posted: Tue Jan 28, 2014 10:43 pm
by ZX4R-F3
Hi Chris,
I have a 1988 ZX4 i was going to rebuild, then transferred the engine into a H chassis.
I have found the majority of parts from the H and L fit the ZX4 motor, as far as i know the engines are basically the same apart from the ZX4 does not have the oil cooler, and the cams are different, the ZX4 has more aggressive cams (keep them). Inlet rubbers are interchangeable 30mm and 32mm as are the carbs
I have L exhaust, H clutch and springs, various gaskets, ZXR generator cover, valve springs, and when i get round to it going to fit H CDI and ignition pick up and see what happens.
Posted: Tue Jan 28, 2014 11:08 pm
by ChristoT
ZX4R-F3 wrote:Hi Chris,
Thank God! That makes my engine rebuild less daunting, thanks!
