carbon tank cover
Posted: Sat Dec 11, 2010 6:09 pm
by zxr500man
Just got it,
its not perfect ,but its not bad,the guy is a beginner,
but its very strong and light!and cheap!
my origonal tank weighed 5.5 kg on my bathroom scales,
this doesent even register!
now i have to desing an alloy tank any tips much appricated,i was thinking about putting a hinge on this tank cover.
not sure.
Re: carbon tank cover
Posted: Sat Dec 11, 2010 6:53 pm
Nice! How much? And how does it fit on?
Posted: Sat Dec 11, 2010 6:57 pm
by zxr500man
he gave me two brackets,im to glue them to the inside the cover,their l shaped,i can bore the brackets to suit,their carbon too.
Posted: Sat Dec 11, 2010 7:09 pm
by sinap
Ben Palmer, raven performace does the ally fuel tanks.they are shaped to fit behind the airbox and hold about 5ltrs.
Posted: Sat Dec 11, 2010 7:22 pm
by zxr500man
ally ,is that short for aluminium?
might just make my own up ,if theres a mistake ,i can only blame myself.
Posted: Mon Dec 20, 2010 4:37 pm
by AFM327
Anyone tried making a small carbon tank? I was thinking about making one for my 400. The plan was to carve a foam block to make the form, and then make the molds off the form. I saw 5 miles per liter mentioned earlier, is that a good estimate for mileage, short course or road course?
Posted: Wed Dec 22, 2010 12:04 pm
by zxr500man
would the petrol not melt the resin that holds the carbon fiber together,not imediatly but after a while .?
Posted: Wed Dec 22, 2010 6:30 pm
I think that would depend largely on the resin used.
Posted: Wed Dec 22, 2010 7:29 pm
by AFM327
No it won't melt the resin, I have a friend who makes them and he hasn't had any issues. And since we'll just be making it to fit under the tank cover it doesn't have to be pretty either.
How are most of the small aluminum sprint tanks bolted to the frame?
Posted: Wed Dec 22, 2010 9:49 pm
by zxr500man
well if thats the case i might get my buddy to make one for me,
i dont know where im going to bolt any thing,i need to get a ram air box first ,just to see what space i have,
it would be that bit lighter being made from carbon too,
Posted: Fri Dec 24, 2010 12:09 am
by AFM327
You could make the air box our of fiberglass, it's much cheaper and will work just as well.
Posted: Fri Dec 24, 2010 5:32 pm
by zxr500man
your right,its just that iv read here some where it has to be a certain shape,
like i would have thought ,if it was really wide at the front to catch as much air as possible,and then a small area around the carbs,
i thought that would create as much down force as possible ,but it turns out not its acturally supose to be a pretty big area around the carbs,
any way i just wouldnt be sure about it,i got a quaote yesterday for 140 including bellmouths from dyno pro racing,
so i think i might go with that,my bike is a h model so i could not find a second hand one.
