wondering what other carb fitments that will bolt on easily to my 88 zx400g?
						zx400g carb fitments
				ZX4R-F3
 - My Bike: 1988 ZX400-F3
Re: zx400g carb fitments
I have fitted ZXR 32mm on mine.
Straight swap as it is the internal diameter that changes so you don't have to change the inlet rubbers.
Also in the process of swapping out the pick up and rotor and using a H cdi. If it works or not will keep you posted.
				buellboy
 - My Bike: buell 1125r
wicked cheers for that
kinda ..ZX4R-F3 wrote:I have fitted ZXR 32mm on mine.
they'll fit.. but there'll be a step from the carbs into the smaller rubbers .. you really need ZXR inlets that match the carbs.
