Running then dies when i let the clutch out !! confused ??
Posted: Tue Jul 09, 2013 8:05 pm
by winnyzxr
hi guys
i picked my bike up 4 days ago, it was fine to start with was running fine
went to go out on it yesterday and it starts up fine, click it in gear let the cluth out and it just dies. i tried to go out again today and it done the same.
any help will be much apreciated
thanks
Re: Bike starts fine then dies when I try to pull away....
Posted: Tue Jul 09, 2013 10:32 pm
by adamm1704
Side stand switch. make sure the switch is all the way pulled out. get a pair of pliers on there while siting on the bike and pull it.
Re: Running then dies when i let the clutch out !! confused
Posted: Tue Jul 09, 2013 11:41 pm
by ross46
Mine occasionally used to do that until I cleaned the switch, but I used to turn the bike off, put the sidestand down and up again and turn it on a press the button, normally worked
Posted: Wed Jul 10, 2013 7:14 am
by winnyzxr
Thanks for your help guys. Will give it a try once I'm home from work and let you know how I get on.
Posted: Mon Jul 15, 2013 10:49 pm
by winnyzxr
Hi guys
Thanks for the help it worked for a couple of days now it's doing it again.... Could it just be a faulty switch?
Posted: Mon Jul 15, 2013 11:39 pm
by ross46
Faulty switch, dodgy connections or the switch might have moved and just needs repositioning
Posted: Tue Jul 16, 2013 10:45 am
by banner001
i would try first bypassing the sidestand switch and see if that cures it.
next, bypass the clutch switch and see if that clears it.
if not, bypass both and that should solve it
to bypass the sidestand switch, unplug the switch and bridge the connector on the wiring loom side of the connector with a paper clip, bit of wire etc, something to make a connection, then see if the bike moves in gear (if you have a paddock stand it makes this very easy).
the clutch switch has 3 wires, you need to unplug the switch and then bridge the wiring loom side's black and black/yellow wires.
