H1 SP Sprockets
jez400
- My Bike: 1989 zxr400 J1 (SP)
H1 SP Sprockets
Currently rebuilding an H1 SP and not sure what are the correct sprockets. It's currently running 16/44. I know that a standard H1 would run 15/45. Would I be correct in assuming that a 16/44 combination has been fitted because the SP gearbox may have a taller first gear? Any help would be appreciated. The last thing I want to do is raise the gearing so that it's impossibly high geared in first.
Re: H1 SP Sprockets
16/44 is correct for the J1
jez400
Re: H1 SP Sprockets
Thanks, appreciate the confirmation. Jez.
Re: H1 SP Sprockets
np , is the engine stamped with a " J " on the block ?
Sounds like it is genuine with the sprockets though.
