46t rear sprocket
ppaauull0
My Bike: Kawasaki ZXR400
46t rear sprocket
Post by ppaauull0 » Sat Jun 30, 2018 8:50 pm
What difference could I expect if I swapped out the standard rear 45t for a 46t, no point in buying and fitting if it makes little difference. Also my front sprocket is quite loose on the spline, the retainer is ok and bolts tight, is this normal. Cheers.
banner001
Track day God
Track day God
My Bike: ZXR400 L4
Re: 46t rear sprocket
Post by banner001 » Mon Jul 02, 2018 3:08 pm
You can use the gearing commander website to properly look at the changes, but the main differences will be that your wheelbase gets slightly shorter, you engine revs for a given speed will be higher etc...
UK ZXR 400 L4
UK ZXR 400 L3 track bike
banner001
Track day God
Track day God
My Bike: ZXR400 L4
Post by banner001 » Mon Jul 02, 2018 3:10 pm
As for the sloppy sprocket, yes it should be a bit loose. If you look directly at it and turn it to the left or right that should be a positive engagement, but it should have some slop when pulling it towards yourself or giving g it a bit of a wiggle
UK ZXR 400 L4
banner001
Track day God
Track day God
My Bike: ZXR400 L4
As for the sloppy sprocket, yes it should be a bit loose. If you look directly at it and turn it to the left or right that should be a positive engagement, but it should have some slop when pulling it towards yourself or giving it a bit of a wiggle
UK ZXR 400 L4
