Wheel spacer dimensions needed
markkaren96
Post by markkaren96 »
I ordered a front wheel off ebay for my track rain tyres, however the bearing spacer tube is obviously shorter then it should be. does anyone know the dimensions of this part (L model Fiche part# 92143B) I can get inner and outer dimensions but need length.
markkaren96
Re: Wheel spacer dimensions needed
Never found dimension. However problem was fixed using spacer. H and L models must have different wheel build with the spacer being larger for the H model.
yes mate, sloweracing is the man to talk to regarding this mod, he's done it many times.
Deswilkie
My Bike: ZXR400L, Trumpet 675
Post by Deswilkie »
Old thread but I've just been through the same issue and after much head scratching discovered there are different part numbers and sizes for these between the H and L models. So to save other folk the potential hassle here's the sizes and part numbers.
For H model front wheel the bearing spacer/axle is 82.5mm, part number - 92143-1324
For the L model the same spacer is 86.5mm, part number - 92143-1479
