So now you're back from outer space.....
Posted: Thu Nov 01, 2007 4:08 pm
by mycallsevern
Hey everybody, I've been away and now I'm back and I have some problems.....
1. The front end of my bike creeks when I brake does any one know what this could be or has anyone else experienced this?
2. My pillion seat doesn't fit properly, it wont locate on the hooks at the front, does anyone else have this problem and any ideas how I could fix it?
Thanks Mike.
Re: So now you're back from outer space.....
Posted: Thu Nov 01, 2007 4:28 pm
where's the creaking coming from? the forks? is the bar under the seat bent? if its not been fitted properly and someones sat on it could have bent the bar or the hooks, or they may have worn?
Posted: Thu Nov 01, 2007 5:31 pm
by mycallsevern
I'm not sure what is creaking, when i roll the bike forward it sounds like it is coming from the discs do you think it could be the carriers? I'm gonna have an investigation in to the seat as I think this is the only way.
Posted: Thu Nov 01, 2007 10:35 pm
by Northern ANdy
mine are warped and creak
Posted: Thu Nov 01, 2007 10:58 pm
by jake
also make sure yr forks are sitting straight in the yokes, and check the bolts are tight. Mine was making a funny noise when braking, and it turned out to be yoke bolts not being tight enuf!
Posted: Fri Nov 02, 2007 8:47 pm
by Northern ANdy
forks straight in yokes? as in same height do you mean?
probably asked already but do you go to the tap jake
Posted: Mon Nov 05, 2007 5:54 am
by mandie82
Is your steering stiff from side to side?...
I first has a squeek when i needed to replace the head stock bearings!!and it has been great for 6 months.
But now my front end sort of creaks or squeekes.. when me and my other half looked at it.. we found that it was the braided hoses that were rubbing on the fender...
Posted: Mon Nov 05, 2007 11:19 am
by zimm
mine used to creak a bit after i fitted crash bungs as the bolts would loosen off until i applied threadlock.
Posted: Mon Nov 05, 2007 12:25 pm
by mycallsevern
Cool thanks for the tips, I think I am just going to have to go over every bolt and nut and find out what the hell it is! Cheers Guys
Posted: Mon Nov 05, 2007 12:35 pm
your headstocks not cracked has it
Posted: Mon Nov 05, 2007 4:19 pm
by mycallsevern
Well I did notice the front rake seemed to have increased the other day! And the ground does seem a little closer!
Posted: Tue Nov 06, 2007 4:46 pm
mandie82 wrote:Is your steering stiff from side to side?...
don't forget the workshop when you want to check adjust replace headstock bearings
http://www.zxrworld.co.uk/zxr400/headstock.html
Posted: Thu Nov 08, 2007 9:01 pm
by jake
Northern ANdy wrote:forks straight in yokes? as in same height do you mean?
Alrite mate..
Soz for no reply, i forgot about this thread...I used to go there coupla years ago, was sein' some bird from down that way..
I go now and again still, not often tho..usually after the egg run or for a pint after a ride.
I normally just hit wales for my rides, pondrossa(spelt right?) and round that way.
have to hook up for a ride sometime when it gets a bit warmer mate
