How to turn a Zorst into a Bike
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Post by Mori Man »
Was hunting about looking for zorst's (as I do :smt002 ) and happened across a BEET Ti system :smt001
Translated the description which tied in nicely with the photos, now the thing was - he couldn't be bothered removing it from the bike so it came with it shocking :eek:
It had a buy it now price and some one asked if they bought it outright would the delivery be included - the seller agreed and I clicked the button :smt003
80,000 Yen delivered to my door = £377.10 :smt004
The bikes a non-runner, sitting for 3yrs and the battery is fecked. I'd assume the carbs are gummed up and the fuel will be off too ! So when it arrives i'll take the carbs off and give them a good cleaning, empty the tank out and put a litre of fresh stuff in , take the battery out my bike and see if i can get it fired up.
Then it will be strip down time :smt003 I'll have my SP front end to put on it so not worried about the USD's , got the triple clamp for fitting the ZX636 USD's on the ZRX and if I dont like the look (doubt) it can go on this too biggrin
And of course I've even got one of these to go on the tank
and I want to find one of these to get the gull arm off it :smt007
(Actually bought the zorst of this one :smt005 )
Need to clear my cupboard now and find my toolbox again :cool:
Re: How to turn a Zorst into a Bike
how many zorsts do you actually own??
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Post by Mori Man »
masterofinsanity wrote:how many zorsts do you actually own??
:smt017 A few :smt003
For my bike i am down to 4 which is good for me - it was 7 and has been 12 geek
For other bikes 3 which is still good as it generally sits around 5 or 6 but i got a few sold last week , but another two will arrive over the next few days so will be back up to normal levels again :smt005
It's a confirmed fetish :smt019 Flippin Titanium "fire effect" :smt007 can't get enough of it :smt016
:smt003
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Post by Mori Man »
BTW, it's about to start with this bike :smt018
Got a BEET on it, I have another system in the pipeline and also want to try a Dual twin pipe race system , can each side :smt007 Tsukigi's are thin on the ground but once i've been to my local track a few times I'll soon suss what the local lad's are using :smt002
Depending on riding position i might go for a top bridge conversion and put bars on it oldman
Should add, the "Hoover" pipes will go as i will put a ram air box in with some FCR's :smt001
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
It beggins
Post by Mori Man »
Bike should arrive some time late next week - actually hoping next Saturday :smt001
Once i get it running I want to do a power check on it as is, then when i start to change things over see what effect they are having.
Priced up the Xanthus arm and is £247 new which isn't to bad if I can't find a used one.
Already have these on their way to give me some options :smt002
Missed out on the carbon fibre ram air box :smt010
Next is to find out what the spec is on the BEET cams compared to SP ones.
drew you make me sick with jelousy sometimes! :smt005
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Post by Mori Man »
RedexRobB wrote:drew you make me sick with jelousy sometimes! :smt005
Better unsubscribe from this thread now then :smt002
Already hunting for a specialized tuner to see what can be done :smt017
Mind you there is plenty info on here but want to see about un shrouding the valves - I'm a dab hand at porting and polishing so can cover that but would hate to remove to much from the head.
Is it possible to put a L9 motor in it without much problem?
If i go big bore and the original motor has low enough miles, it will get the make over :smt001
all zxr engines will bolt in mate, think the thermostat housing needs turning 180 degree's if going L to H or vice versa.
hciR
Post by hciR »
That's gotta be the deal of the century! well done.
<whisper>
... epoxy ..
</whisper>
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Post by Mori Man »
hciR wrote:That's gotta be the deal of the century! well done.
Thought that too :smt003 so rounded it up to £400 :smt001
zimm wrote:<whisper>
... epoxy ..
</whisper>
:smt005
carsounds_dan
Post by carsounds_dan »
i had a set of beet cams, they didnt really see all that different to the sp ones... nothign you could visually see anyway
...i know, it's great :D
still got em ? wanna sell em ?
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Post by Mori Man »
carsounds_dan wrote:i had a set of beet cams, they didnt really see all that different to the sp ones... nothign you could visually see anyway
After finding out that the BEET are double the price of a set of SP , I think I know where I will be getting my cams from.
What's the UK price on Kwak SP cam's?
Any advantage having a ZXR400M ignitor box over the H?
Are the valve springs stronger in the M motor and is it good practice to fit the followers too?
Cheers guys,
DS :smt001
if by "M" you mean SP (rather than uk spec 21119-1332 M) then yes, but you'll need a whole loom and ignition rotor to match it. IIRC its a slighly diff advance curve, higher rev limit, and ability to map a TPS off the flatties.
been thinking the same thing as there's one on ebay .. dont think i can be bothered though, most folk here seem to run stock cdi's (1332), get them modded, or replace with aftermarket programmable stuff.. which is probably the way i'll go if i change from stock (more to fiddle with :smt003 )
afaik springs/followers are the same, but i couldnt swear to it.
