did run wont run
- My Bike: zxr 400 l4
did run wont run
hi i wonderin if anyone cud sort this mess out i was comin home for work on the m1 at about 85mph bt as soon as i hit the indicators to come off the bike stalled then backfired an started again but ran fine until i hit the brakes of anythin electrical. after pushin for four miles to get it home i noticed the leds on the dash were dim and the bike wudnt fire but the relay in the junction box chattered i have since swaped the battery, starter solinoid, junction box and fuel relay and it just did the same but now the ignition switch is playing up aswel so soon to be replaced but if uve gt any idears just let me know plz
- CBT slow
- My Bike: zxr400 H2
Re: did run wont run
u checked the alternator is working ok?
- Scott221
- Restricted
- My Bike: ZXR400 L9
A little similar to the problem i had on my eliminator 125 only last week.
Check all the wires on the ignition switch as mine had come clean off on mine, just check that all the connections are good and strong.
- markzxr400l3
- My Bike: ZXR400H2 GSXR750
Charge the battery, switch on the ignition and fire it up (if you have a dicky starter circuit connect an car jump lead from the positive battery terminal to the starter connection --- vroom!!) btw if it is actually the solenoid then you can just 'jump' the two 10mm nuts with an OLD screwdriver - sparks like a b*ugger tho.
whens its up and running check the voltage across the pos and neg battery terminals, if over 13v youre okay but if not then you need to replace the regulator/rectifier or you have an alternator problem. To work out which, disconnect the regulator, start the bike, rev to 4000 rpms and measure the voltage across the any two wires coming to the rectifier from the alternator, cant remember the actual voltage (check the manual) but methinks its meant to be about 14.5volts or thereabouts. Important to get the revs up though cause at idle its lower.
My money is on regulator - 20 quid, second hand, fleabay, snip.
Good luck mate.
Good luck mate.
