I'm new to this forum having purchased a ZXR400 race/track bike off of Ebay for £1600. It got dropped off the other day and was looking similar to this.
According to the Dynotech Performance Invoice sheet that came with it in 2004 it had an engine blue print and tune, race head flow, race cams and stainless steel valves put in,
a race ignition added
A race kit airbox fitted, cylinder rebore, ohlins rear shock fitted and the forks stripped and rebuilt.
The fella I bought it from said it had only done part of one season since then and after that had just been standing around.
I spent last night stripping it all down to see what condition it was in. I lost count after the 20th cable tie holding things together
The oil cooler and Radiator were looking really shabby, the radiator was missing a tab. When I drained the coolant it came out brown and rusty!
One good thing was it came with what I think are titanium headers. Despite being all dirty making it hard to tell they were so light they had to be Ti.
The frame and the swing arm are in good condition as was the battery. The triple tree is very pitted with white corrosion type stuff.
The exhaust outlets were very sooty making me think it was running rich for a long time and that may need sorting.
These are the calipers it came with. The braided lines are good but not coated in in a plastic protector to stop rubbing. They are tokico 4 pots with a Nissin master cylinder, is this standard?
The brake pads look a bit rusty but I don't think the brakes are seized. I may well strip them down and repaint them anyway to get them looking nice again.
I have a lot of questions having never owned one of these before. I have been pouring over the forum trying to pick up information here and there to help me.
If anyone could give me pointers on the folowing I'd appreciate it.
Given that it's had all this engine work done but hasn't run really since 04 - 05 is it worth stripping it down and replacing the valve springs.
At the same time I could clean up the piston heads if they need doing.
The oil when drained didn't look particularly clean but I have seen worse, The cap did have a bit of white emulsion in it, is this an indicator the head gasket could need replacing anyway?
I had some more questions but they have slipped my mind now. Hopefully I'll have it back up and running soon. I already picked up some Dunlop alpha 10's for it.
Max
