Brake calipers for H1
wayno
My Bike: FZR600R
Post by wayno »
Hi all
I want to fit some different calipers to the front end of a 400 H1, I have read all the threads about the 6 pots being a bit pony so don't want to fit them. Can anyone tell me which other calipers will fit onto my forks, and what mods I'll need to make them work.
Ta
Wayne
Re: Brake calipers for H1
have a look through this thread, might help?
viewtopic.php?f=55&t=2743
Whats the distance between the mounting holes?
wayno
My Bike: FZR600R
Post by wayno »
I think they're standard 62mm between centres. I'm not sure what size discs as I don't have any on there (I'm building up the front end of a ZXR400 H1 to go on a Zephyr 550), I read a thread on here that said the H1 has 300mm discs (which are the same as the Zephyr), but if you swap to normal 310mm discs you can use other calipers
H models have 300mm discs, 310's will "just" rub the caliper body.. the 6 pots will allow you to fit the 310mm discs, not sure about the k1 4pots.. but probably
wayno
My Bike: FZR600R
Post by wayno »
Cool, I think I'll get a pair of k1 4 pots then, I can try them with the pair of 300mm zephyr discs I have, if the discs are too small for the calipers I'll get the bigger ones.
I understand the L's use a 310mm discs, does anyone know if these are a straight fit on the H1?
identical except bigger.. if that makes sense..
will#224
My Bike: L1 racer
Post by will#224 »
So your selling your H1 calipers?
wayno
My Bike: FZR600R
Post by wayno »
No, I don't have any calipers at the moment.
Identical but bigger does make sense, thank you, at least I now have more choice of discs smiler
will#224
My Bike: L1 racer
Post by will#224 »
if you dont have any calipers, you could get direct fit, the calipers origionally fitted to h1 are still fitted to bikes today. zzr600/1100/1200 and several others. They are on ebay cheap too. Brand new are only £200 a pair with pads
