looks like that fiberglass could do with being sanded down alittle!
i put Duke 749 mirrors onto my 750 think it improves it 10x
Finally finished my exhaust bracket
Re: Finally finished my exhaust bracket
Those pictures were from last year, smoothed them over and re-sanded them down yesterday and are 100 times better now
What you on pupp?
What you on pupp?
- My Bike: Unique ZXR400
You filled them then?
I cut the rasied bit off, glued a motrax indy spacer on the back of the hole, dropped some mesh into the glue on the outside of the hole. then body filler and filed/sanded flat. Should of got a pic before I took it back to the bodyshop. Oh well. I have mirror indies for it RobB.
Andy
just took the indys off mine filled the back full of filler then sanded down the out side, came out perfect cant tell the diffrence at all
i glued a bit of plastic on the back, filled the hole with filler and then sanded down with 1000 grit wet n dry. I filed the protrusion of the moulding down and took most of the excess filler off too with it.
