Re: Overheat, coolant and a dead fan? HELP!?
Posted: Thu Apr 09, 2009 8:04 pm
Interesting one this..................
Race bikes are only allowed to run with water.............I used to use distilled water when I could get it for free
Anyway if my race bike got much more than 90c I'd start to worry a little. My ZXR400 with water and no fan has NEVER reached half way on the standard temp guage
Jeppo your fan gets it's signal to switch on from a switch in than radiator that switch reacts to a high water temp not sure at exactly what. Given that your radiator was empty the switch wasn't sensing a high water temp cos there was no water there !
Now to the real problem............if you short the wire on the brass swtich fitting on the front left of the rad the fan should come on...............if it doesn't then the switch COULD be fecked...................if you apply 12v directly to the fan and it spins then it is ok if it doesn't it's fecked..................replace the fan and retest the brass switch connection again the fan should come on if not its fecked
