Hi everyone,
just had a nosey at my cousins 400 inside the inspection cover was a half moon bit of metal snapped of the cam chain guide above the tensioner,
noticed going through the receipts when we got it that it had both of them replaced at 5k now on about 11k and the one nearest the exhaust has gone,
taking it its a barrel/ head of job,
what I was wondering is what causes them to go on the kwacks, poor design? low quality metal, or bad riding and abuse really enjoying learning about yet another bike
also how long do you tend to get out of them when they are replaced
Thanks,
Tom
cam chain guide exhaust side
- My Bike: rd 350 lc, gixer 750l1
- Restricted
- My Bike: zxr 400 l6
Re: cam chain guide exhaust side
Half moon shape bit of metal is normally of the inlet side where the tensioner pushes the guide, yes it is a head off job, unless you drop the engine then you should be able to do it just by taking the rocker cover off, regards, ross
- My Bike: ZXR400 L3
Did it look like this?
Found this in mine. Chain and guides being replaced next week so will see if it came off the guide.
yup, thats a broken tensioner blade...whilst your at it you should also check the camchain tensioner to make sure the ratchet mechanism's not broken, and check the tension of the camchain as well.
randal has done a good sticky thread about changing the camchain in one piece, and also about how to align your camshafts back properly afterwards...remember, 31 pins between camchaft timing marks.
- Restricted
Yeah, here's the thread banner is talking about
viewtopic.php?f=117&t=13874
I managed to change my cam chain using this method, getting the old one out was more of a pain tbh, banner, did you do yours in the end?
