I went to my cam chain and couldn't see a way of doing it without removing the cam shafts
Do these need to be removed of is the a way of doing it without
Removing cam when changing chain
- My Bike: ZXR400 L2
Re: Removing cam when changing chain
you will need to remove the cams for sure. Careful undoing the cam caps and undo each bolt evenly or you risk cracking the cam caps.
- Restricted
- My Bike: zxr 400 l6
remove the cams, support the chain somehow (rest an Allen key through the chain and on the head, or tie up with a bit of string to the mirror) then remove it, if you dont support it, it will fall down and coil up
