Removing cam when changing chain
Posted: Sun Dec 15, 2013 11:25 am
by tink
I went to my cam chain and couldn't see a way of doing it without removing the cam shafts
Do these need to be removed of is the a way of doing it without
Re: Removing cam when changing chain
Posted: Sun Dec 15, 2013 11:49 am
you will need to remove the cams for sure. Careful undoing the cam caps and undo each bolt evenly or you risk cracking the cam caps.
Posted: Sun Dec 15, 2013 4:39 pm
by ross46
remove the cams, support the chain somehow (rest an Allen key through the chain and on the head, or tie up with a bit of string to the mirror) then remove it, if you dont support it, it will fall down and coil up
