Engine Removal - best way
Posted: Wed Jul 22, 2015 9:16 am
by Moonfire
Hi, I'm about to remove the engine from an L3 at the weekend to do the cam chain and wondered if anyone could advise as to the safest way to support the engine on the way down and the easiest way to lift it back up and in again.
I'm thinking of building some sort of tray that could go under the engine and somehow (?) attach it to a trolley jack, but realise that unless I get it right, it's like to rotate and fall off the jack when I remove the last bolt. Has anyone got a tried and tested favourite way of doing it and/or have any idea how much it weighs? I couldn't find it in the manual but I'm guessing with an all up weight of 162 kgs it's somewhere between 50 and 100 kgs and needs a jack?
Many thanks.
Re: Engine Removal - best way
Posted: Wed Jul 22, 2015 12:52 pm
by banner001
its easier to remove the camchain with the engine still in the frame...you will just need to get an inspection mirror so you can check the alignment of the cams.
i use a trolley jack and support the base that way, it doesnt need to pitch or rotate so that makes it easier. a second pair of hands/helper is all you need.
Posted: Wed Jul 22, 2015 4:09 pm
by Dominik
The engine weighs a little less than 50kg depending on parts (not) removed (header, radiator). If you only want to do the camchain it´s enough to tilt the engine. You remove the upper front bolts and the upper back one. Than you can tilt it around the last bolt and do the work.
If you want to completely remove it and do it the 1st time you should get a second pair of hands to help you. As you can hold the enginge alone it will be more or less easy with two..
Posted: Wed Jul 22, 2015 7:31 pm
by Moonfire
Thanks guy's that's great.
As ever, thank you for your advice, it really is appreciated.
Posted: Mon Aug 10, 2015 5:37 pm
by Lucky Eddy
if you want the engine out in a couple of minutes without a jack etc then heres what to do.
- get everything disconnected so it is ready to drop
- with the bike on the ground on a rear paddock stand loosen all the mounting bolts
- remove the front bolts one at a time and replace with screwdrivers or similar
- shimmy under the engine and support it on your knees/legs
- with the engine supported on your legs you can adjust height until the rear bolts can push out by hand
- remove the screwdriver(s) from the front
- slowly lower the engine onto the floor onto wood or carpet etc by adjusting your legs
- slide out
I can usually take the engine out and back in a few minutes single-handedly..you just need to make sure all the bolts are reasonably free and moving. If you have to drift them out so far they will still support the engine if you are careful. Done this loads of times on 400's & 600's etc...doddle.
Posted: Tue Aug 11, 2015 1:11 pm
by 400y
or
disconnect all pipes, wires, etc and just put the bike on its side on the floor, obviously take the engine bolt nuts off first and lay down that way.
Support engine with a few blocks - wiggle engine bolts out and thats it.
Posted: Fri Oct 16, 2015 7:33 am
by Moonfire
Many thanks for your advice guys - much appreciated.
