Hi all.
Have just changed seals and oil in my front forks on a 89 ZXR 400 H1 model. Trying to adjust them and have looked at several guides on setting up. Found that 30mm is reccomended static sag setup. I would the preload to its hardest setting and checked preload and found it to be 19mm. I then started winding it anti clockwise and found as ive done this it has made it smalled. I have now found in manual it says 1/4 turn from been full anticlockwise. I have set it like this but are now only getting 5mm on sag from sitting in riding position to stood upright off stand. Please can anyone help?
Thanks Adam
Forks Not Adjusting Correctly?
- My Bike: ZXR 400
