oil window
Posted: Thu Jul 30, 2009 1:34 pm
when bike is level should this window look full of oil or should it only show up half way,mine is full i have a feeling there is to much oil in the bike.
https://www.zxrworld.co.uk/zxr400oc/
https://www.zxrworld.co.uk/zxr400oc/viewtopic.php?f=165&t=9800
Thats what i was thinking,ill drop some out now.Wabby wrote:Half way when level.
If you have it on a rear stand, you will need a front stand to make it 'level' though.
Yes once the bike is running looking at the window will tell you nothing as the oil is too busy doing it's job to have time to tell you what level it's atChris1984 wrote:i have just droppe some oil out but when i start the bike it drops even further is this ok.
Nice one thanks i've been riding around with way to much in,going for a spin now to say sorry to her.cargo wrote:Yes once the bike is running looking at the window will tell you nothing as the oil is too busy doing it's job to have time to tell you what level it's atChris1984 wrote:i have just droppe some oil out but when i start the bike it drops even further is this ok.
Also having it on a rear stand when you check the level is fine you don't need to put it on a front stand as well....................the bike needs to be upright in one plane only (side to side).
Anywhere between the two little marks on the side of the window is fine.
When doing an oil and oil filter it takes about 3 liters..........................pour your oil in until you see it about half way between marks. put the filler cap back on and start the bike for a minute or so. Stop it and allow the oil to settle recheck the level and top up if neccessary.
Job done
good question and I don't know the answer not ever tried putting too much oil in I suppose you might end up with an oilly mess in the air box via the breatherDannyMcCann wrote:Whats the consequences of too much oil? Apart from burning a bit off?
Unless you've got worn rings or leaky valve stem seals then no I don't think it would "just burn off"RedexRobB wrote:Isnt it possible to blow gaskets with too much oil? And doesnt it sometimes just burn off?
