Hi all,
ok so my downpipes are rotten, my can is blowing and has a huuge hole in the back of it so im going to replace it. its a stubby micron can i have at the moment.
Im thinking of getting an oval can with a bit of carbon fibre or iridium on it i want it standard size and instead of the tube kind of coming out i want a kind of tapering one if that makes sense? im thinking of getting it from A16 as they r pretty good and they are going to get the rest of the system from a company called hindle a stainless steel system held together by spring clips. any thoughts on this?
basically i want one that isnt obnoxiously loud but enough that it will make sure everyone looks in their mirror to see the source of the noise when im overtaking etc. i also want it to be very deep and bassy rumbling especially when it idles although i dont mind it screaming a bit when i open the throttle lol again anyone know of anywhere or brands or comapanies theyd recommend?
also my current exhaust does this thing when i rev up where it kind of backfires a bit and shoots a flame out. i know it does it if i rev when static and it sounds like when i shift gears above around 12000rpm it does it (i cant look round and see for obvious reasons). is this a bad thing cos i think it looks and sounds quite cool and if its not gonna cause problems can i make sure it still does it with a new exhaust?
sorry for the length of the post just wanted to include as much info as poss. finally its off topic but it saves me doing another post, one would the L model front fairing fit my H model? i just prefer the two headlights to be under one lens lol and second can i get the double bubble screen for either of the fairings depending which will fit. if so where can i gt it from?
thanks all and thanks in advance for replies
Buying New system
- My Bike: ZXR400H2
- CaNsA
- My Bike: ZX6R F1
Re: Buying New system
- My Bike: ZXR400H2
thanks man. you reckon ill still get my little backfire thingy? my friend said another way to make it happen it to tweak my carbs or summin like tht??CaNsA wrote:http://www.mtcexhausts.co.uk
Had a full system on my 1st zxr. It was toad hot and sounded really nice.
and they are a little expensive for me loool
if my old and extremely scarastic memory serves me right a backfire from the exhaust on a just closed throttle is an indication of weak mixture.
So just lean it off a bit and you'll get all the popping and banging you want...........
- Tirpitz
- My Bike: Kawasaki ZXR400L4
You're currently wrecking your engine as it is clearly running way too lean - hence backfiring etc. If you carry on with this much longer you will have burnt all your valves and will probably have a hole in a piston or two - your exhaust will be the least of your worries then. Stubby cans are not road legal, should fail an MoT, will get you fined if you get a roadside check by Plod, and are not compatible with the original carb set-up.
You need to stop p*ssing about if you're serious about running the bike and not just trashing it. If you replace the downpipes with non-OEM and the can with something aftermarket there is every chance that you will need to pay for some dyno time to have the fuelling sorted out. It sounds like it is already way out as said above. It's going to cost you about £20 per dyno run then the time for the guy to rejet the carbs plus parts. There's no point at all doing anything unless you're prepared to do it properly and get the fuelling set up correctly after you have replaced the exhaust, as otherwise you'll soon be looking at a broken bike and a lot of wasted money.
Having said that the A16 road legal carbon can on OEM downpipes does not need a rejet and clears up all the factory flatspots.
Hel braided hoses
Pirelli Diablos
Ohlins steering damper
A16 carbon fibre exhaust can
Nitron Sport shock
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
Tirpitz wrote:You're currently wrecking your engine as it is clearly running way too lean - hence backfiring etc. If you carry on with this much longer you will have burnt all your valves and will probably have a hole in a piston or two - your exhaust will be the least of your worries then. Stubby cans are not road legal, should fail an MoT, will get you fined if you get a roadside check by Plod, and are not compatible with the original carb set-up.
I could not agree more but he wanted to wreck his engine.......................why should I care
