Engine rebuild
Kevin Steele
- My Bike: KAWASAKI ZXR 400
Engine rebuild
Re: Engine rebuild
where are you based ? not much point recommending someone 300 miles away..
Re: Engine rebuild
budget £700 for a complete full engine rebuild, thats all gaskets, o rings, seals, rings, clutch plates, springs, valve seals, chains etc...plus labour/transportation/damaged parts.
Kevin Steele
Re: Engine rebuild
Thanks for the responses there, I am based near Rochester in Kent, so please can anybody advise of somebody worthy in this area ?? the motor does run, and to be honest sounds quite sweet, however it is leaking some fluid from somewhere, but only a dribble, I think the bike has covered about 38.000 miles ? so naturally as a totally unknown quantity, I would like it checked over, and get done whatever is needed, and maybe good be updated ?? thanks
Re: Engine rebuild
if its leaking oil its probably shift shaft seal or gearbox oil seal that has gone, shouldnt require a full stripdown, just splitting the bottom end would do it
Kevin Steele
Re: Engine rebuild
Can anybody recommend anybody in Kent to carry out engine work please ??
