Hello & advice please?
stuw00d
Hi All
Just got my ZXR400H, H reg, 1991.
Love the look & handling of the bike (my first big bike!), can anyone tell me whether it is possible to lower the seat height a little? I'm a short ass & would like to get my feet flat! Currently the shock is right at the top.
Also, I will be replacing the speedo cable this weekend, how easy/hard? Any advice?
Thanks & sorry for all the questions.
Stuart
Stuart
hi mate, welcome to zxrworld, in the past people have shaved some of the seat foam off to gain the odd inch, it makes all the difference, ask any women!
stuw00d
Hi
Not to keen on the idea of this unless it is necessary, what I mean is, is the ride height adjustable?
My rear shock appears to be set at it's highest point, I was wondering if it is possible to drop it a bit with a C spanner?
Cheers.
Cheers.
masterofinsanity wrote:hi mate, welcome to zxrworld, in the past people have shaved some of the seat foam off to gain the odd inch, it makes all the difference, ask any women!
- deviant
- My Bike: ZXR400 L3
I would have thought you could.
might alter the handling a bit by making it sit butt end down. but you'll never know until you try.
hehe not really something i've ever had to worry about being 6'4"...more concerned about bashing my knees on the fairings.
welcome btw
dave
welcome btw
dave
stuw00d
Excelent, thanks for that, just need to get a C spanner now.....
Here are some pics of my ZXR400, my first big bike
http://www.mediamax.com/wood17/Hosted/Front%20left.bmphttp://www.mediamax.com/wood17/Hosted/Left%20side.bmp
http://www.mediamax.com/wood17/Hosted/Right%20side.bmp
Sorry if the links don't work but this is my first time posting links.
Let me know what you think.
Cheers.
Cheers.
- deviant
looks pretty smart
- BigNinjaDave
- My Bike: ZXR636, ZXR400
stuw00d
Any advice on dropping the front?BigNinjaDave wrote:Hey mate welcome to the site![]()
If your planning on dropping the ride hight at the rear I would consider doing the same to the front otherwise you will slow the stearing down making it harder to get the bike to change direction.
I am a bit of a numpty when it comes to all this, but am willing to my hands dirty if it means saving a few quid!
Cheers.
Caz
- My Bike: GSX-R600 K4
I wouldnt advise altering the rear ride height by changing the preload on the shock.
If you must have it lower, then consider getting a different dogbone made up and dropping it through the yokes to keep the suspension geometry the same.
GIYF http://www.sportrider.com/tech/146_0210_lower/
GSX-R600 K4
ZXR400 H2
Commuter: Gilera Runner 180SP
ZXR400 H2
you can actually adjust the ride heing of the shock, theres two large nuts at the top of the shock when it mounts to the frame, very akward to get to but you can adjust it via these nuts. Altering the preload doesnt necessarily change the ride hide, it changes the amount of pressure needed to overcome the spring, dont mix that up with stiffening the spring cos it doesnt.
- deviant
you've contradicted yourself there rob.
it will change the ride height of the bike when you are sat on it, so you will be operating over a different proportion of the shock's travel (and if you do it to far you might run out of travel at one end or the other)
it wont change the stiffness of the spring.
Caz
you beat me to itdeviant wrote: it will change the ride height of the bike when you are sat on it, so you will be operating over a different proportion of the shock's travel (and if you do it to far you might run out of travel at one end or the other)
The only way of satisfactorily lowering the ride height is by means of a different linkage, and even then you will be altering the suspension geometry. lowering the rear will lead to changing the rake and slower turn in so to compensate for this you ideally need to shorten the forks which can be done by dropping it through the yokes. By lowering the bike you will also loose ground clearance which may become an issue on track or very enthusiastic road riding.
I cant get my feet flat on the floor on my ZXR (and Ive got the rear jacked up 5mm), and I'm right on my tip toes on the gixxer - I'm 5'7" I've got short legs for my height! I get on just fine with it - you just need to take some time getting used to it
GSX-R600 K4
ZXR400 H2
ZXR400 H2
stuw00d
Ok, so the preload is the large nuts around the middle of the shock right?
Sorry, I am still a bit of a numpty when it comes to bike supension!
Mine is set with the nut, right at the bottom of the thread on the shock, what I want to know is, is this right?
The rear end does feel a touch hard & the bike seems higher than other ZXR's I have sat on.
Cheers.
Stuart
Cheers.
Stuart
