Slipper clutch
kermit the frog
- My Bike: zxr400 L9
Slipper clutch
ive heard a rumour that the zxr400 has a very basic slipper clutch, is this thrue?
also does anybody now how to get a zxr400 or any bike backing into a corner?
never give up!
- Ballsout Racing
Re: Slipper clutch
I have heard that they are, but, I've never heard of anyone in the racing world that has actually got one set up to work. I've had my clutch slipping on the power and yet it does not work as a slipper clutch. When you read this: http://homepage.ntlworld.com/webzxr/zxr750r/, that tells you how to 'tune' it to work, you'll understand why I said what I did and am not sure at all that they actually are a slipper clutch in the 400
As for backing it in, I would suggest that you've got a lot more to learn before you try doing that, you'll end up on your arrse for sure. But, brake very hard so that the rear tyre is hovering/sliding over the tarmac, then start turning the bike (as a matter of fact, doing that will show you how obviously you are countersteering
), the back will start coming around, then ease off the brakes to controll it. Or/and use some rear brake to get the same effect. Good Luck
, I would suggest trying it in an empty car park, and take some spare levers with you
Oh, and it'll be a lot more difficult doing it from 100+mph into a, say, 60mph corner and carry a decent corner speed, doing it all smoothly, and not come off
One final point, Why? you gain nothing, the only thing that it may help with is to make yourself wider going into a corner so that anyone behind you won't so easily be able to sail past you into the corner
, although I do admit it looks good
kermit the frog
Re: Slipper clutch
yeh i do agree, i have very,very much more to learn, i just wondered how to do it thats all, i wont try it on the road!!
never give up!
Re: Slipper clutch
they do work, but need time consuming fiddling and the random factor..Ballsout Racing wrote:I have heard that they are, but, I've never heard of anyone in the racing world that has actually got one set up to work. I've had my clutch slipping on the power and yet it does not work as a slipper clutch. When you read this: http://homepage.ntlworld.com/webzxr/zxr750r/, that tells you how to 'tune' it to work, you'll understand why I said what I did and am not sure at all that they actually are a slipper clutch in the 400![]()
had an L engine (they were only fitted to L's) in an H2, and that worked so well that you couldn't bumpstart the bike at all, but it didnt slip under power one bit. The stock clutch in my L4 was ostensibly the same, but set so tight the back would chatter and lock all over the place.
rover220
- My Bike: zx7r p6
Re: Slipper clutch
it does indeed chatter all over the place yeah and likes to lock too.zimm wrote:
d00ner
Re: Slipper clutch
n00b question here.. what is a 'slipper' clutch ? as opposed to a normal one?
the graveyard: honda h100(red) gilera dna 50(yellow) kawasaki kx125 (green) honda crf 450(black) x-sport(orange)
Re: Slipper clutch
a slipper clutch prevents rear wheel lockups when you downshift to the next gear, it does this by allowing the plates to slip when off the throttle but not allowing when accelerating.
kermit the frog
Re: Slipper clutch
well i know mine aint got one after locking up in the wet this morning.
kermit the frog
- noelb
- My Bike: ZXR4H , H'Berg , BMW R12S
Re: Slipper clutch
Did you have to buy the thinner plates to set it up or is there an easier way - thinking of getting an L one for my H race bike.....
Noel B.
Noel B.
Re: Slipper clutch
- ray66ross
- My Bike: ZXR400L-race Street3-road
Re: Slipper clutch
Hello mate - Have been busy racing as much as poss this year - all East fortunr events, Knockhill, and even managed a Croft - what a track!!!!zimm wrote:they do work, but need time consuming fiddling and the random factor..Ballsout Racing wrote:I have heard that they are, but, I've never heard of anyone in the racing world that has actually got one set up to work. I've had my clutch slipping on the power and yet it does not work as a slipper clutch. When you read this: http://homepage.ntlworld.com/webzxr/zxr750r/, that tells you how to 'tune' it to work, you'll understand why I said what I did and am not sure at all that they actually are a slipper clutch in the 400![]()
During all this managed to drop a valve ay East fortune, new engine purchased off fleebay, it has a slipper clutch , but i think the stack is too high for it to work as a slipper , do you know of anyone who can tell me the best height of stack of plates for racing?
Fatspanner #66
