over heating
Rick.O
over heating
Post by Rick.O »
does anyone know why a race bike would over heat? Its ok for 3-4 laps and then it goes into the red or onto the H.
Re: over heating
I take it the coolant was done recently(ish) and its topped up, so possibly head gasket or the thermostat, or maybe even fuel settings if its running lean. :smt001
Check the thermostat first, theres a test in the manual for it, costs you nothing. :smt001 If thats ok then a compression test might be in order.
Rick.O
Re: over heating
Post by Rick.O »
Thanks, coolant has been changed (water only, no aditives)and thermostat has been removed so it looks like it may be the head gasket then?
Re: over heating
Rick.O wrote:Thanks, coolant has been changed (water only, no aditives)and thermostat has been removed so it looks like it may be the head gasket then?
fraid so vsad
edit :
is it dumping water ?
do you still have a fan connected ? if so does it come on ?
it "could" just be a dodgy temp gauge circuit if you're really lucky, check all the wiring for shorts, and test the gauge as per the manual.
Rick.O
Re: over heating
Post by Rick.O »
its chucking water out like mad. Ive pressure tested the rad and it overflows at 1 bar ish like it should do but when its on the bike it over pressurises when the guage gets to about half way. the fan has been removed.
I have tried 2 different rads and another water pump, last year I had to tape the rad up to keep it warm.
Re: over heating
head gasket for sure then, get it changed and it'll be fine :)
