sp model
Re: sp model
Can't believe no one answered this -
YES
What sort of info you needing ?
Fully adjustable front & rear suspension
FCR carb's
Adjustable cams
Closer ratio gearbox
Single seat
YES
![:smt003](./images/smilies/003.gif)
FCR carb's
Adjustable cams
Single seat
- My Bike: zxr400rr
Re: sp model
cheers thanks for that, whats a way of gettin good power out of one, ?? and whats the top end speed on them ??
Re: sp model
Full Exhaust
Ram Air box or pods or trumpets
Should see it showing an indicated 160 no probs
- My Bike: zxr400rr
Re: sp model
160kph ?? thats not a hole lot lad is it cause of the close ratio box or what??
Re: sp model
Errr who said KPH ? Lay off the
medicine ![:smt005](./images/smilies/005.gif)
![cough cough](./images/smilies/cough.gif)
- My Bike: zxr400rr
Re: sp model
ah i thought tat cause there is no way a 400 could do 160mph lad !!
Re: sp model
he did say indicated ![:smt002](./images/smilies/002.gif)
- My Bike: VFR400R NC24
Re: sp model
Top speed depends on your weight and the gearing you have it set up but 130ish shouldnt be a problem.
If you want massive straight line speed though don't by a 400!
The SP is a good model though. Tuneable with lots of goodies to start with (mori has mentioned most of them above!)
Just make sure the bike is an actual SP and not just an SP replica
Re: sp model
Wots a SP replica never seen one of them
Re: sp model
Top speed has nothing to do with weight - that just changes the time it takes to get there.
- mick41zxr
- My Bike: ZXR400sp
Re: sp model
Had my race bike recorded at 221kph on GPS if that helps
