Broken my clutch
zxr400er
Broken my clutch
Post by zxr400er »
So I'm not afraid to admit it, I've made a mistake. I'm not sure what I've done but advice is welcomed to avoid it again!
I recently swapped the clutch basket on my zxr as the old one was rattling, after doing this the clutch wouldnt bite. I just got around to taking it apart to investigate and I found this:
I've obviously done something quite wrong!
Advice guys?
P.S if anyone has a spare I'm after one. :smt002
Robbie
My Bike: zxr400
Re: Broken my clutch
Post by Robbie »
The problem is where has the bits gone that have broken off and what damage have they done??
zxr400er
Post by zxr400er »
They were sat inside the centre hub of the clutch. Not anywhere for them to go fortunatley. Also the bike was only ran for about 5 minutes since and not ridden (as there is no clutch...)
Robbie
My Bike: zxr400
Post by Robbie »
happy days then :smt003
Aint seen you for a whiler 400er. Arent there 4 bolts that go in those holes? Any chance of overtightening? May well be that before you put it in it was already damaged?
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Post by Mori Man »
You haven't aligned the plate to the inner hub properly.
Look at the workshop manual it shows you two marks you need to align right. When you torque up the mounting bolts it will press the pressure plate in properly.
Not aligned it "floats " and as you rev up the engine the pressure plate feels the full grunt of the engine hence the mounting point failure.
When installing the frictions also note to offset the last one too.
MM!
zxr400er
Post by zxr400er »
Thanks MM, I'll look into it if I can get a spare!
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Post by Mori Man »
zxr400er wrote:Thanks MM, I'll look into it if I can get a spare!
13187-1075 About 30quid new
zxr400er
Post by zxr400er »
£52.08
Bit more than I want to pay tbh...
Anyone got one?!
razzcolio
My Bike: ZXR400L1/VT750C2B/VT600
Post by razzcolio »
i need one two :P
