Page 2 of 2
Re: another HG thread..
Posted: Sat Feb 18, 2012 5:37 pm
by thomp1983
oil is thinner and runs out better when warm, id remove the oil as a matter of course for any internal engine work then put some fresh in for a couple of hundred miles then drain and replace it again, if ive left the old oil in and drain it after the job i wouldn't know if any bits in it were pre or post the work i did, start with fresh oil that's drained a short interval after the job has been done and anything in it is likely to be from me poking around, saying you'd comment wasn't a dig but more of a nod to the fact you know more about working on these than i do
chris
Posted: Sun May 12, 2013 8:18 am
by Andy m
Warming it up helps to loosen bolts and nuts,if headgasket gone oil will have to be changed so its better to drop it while warm surely.
:smt015
Posted: Fri Jun 07, 2013 5:43 pm
by CaptMoodyPants
Hi, i need to change my head gasket too, i have a question....will i need to buy new head bolts and washers or can you use the old ones?
Posted: Fri Jun 07, 2013 5:52 pm
There was a thread on this not that long ago. Iirc the manual states they need replacing but i think alot of people dont bother.
