Page 2 of 3
Re: how to set up your carbs
Posted: Wed Aug 07, 2013 11:13 am
by maelstrom
Ok, got that. You need to send me a shipping address too.
You can use any images you like so long as somewhere you make mention of where they came from, I'm happy.
Blair
Posted: Wed Aug 07, 2013 11:26 am
by ross46
send me a personal email address and we'll talk more on that unless the liketek is yours?
Posted: Wed Aug 14, 2013 2:48 am
by maelstrom
Ross,
"unless the LiteTek is yours"
I am not sure what you mean? LiteTek is mine, the carb kits are produced by me and the photos are taken by my good friend James. They are not made by someone else. Some photos, like those for the Yamaha FZR400 1WG assembly guides, were sent to me by a customer with his blessing.
Blair
Posted: Thu Aug 15, 2013 2:11 pm
by KwakKwak
This is a great guide Ross, using it at present to standardise my carbs, one question, hopefully not a stupid one, when I drained the carbs, 4 and 3 drained out a similar ammount of juice, 2 was empty, 1 poured out, is this normal or a symptom of badly set up carbs, bike was running badly to say the least, Viton kit on its way too
Posted: Fri Aug 16, 2013 10:45 am
by ross46
Could either be badly set up carbs with the floats set wrong, had you taken the carbs off at this point? When I take mine off I normally have some fuel come out of the overflows but normally drain a similar amount, if 2 has no fuel then it could be the float is stuck closed not letting any fuel into the float bowl making the bike pretty much run on 3, any questions just ask
Posted: Fri Aug 16, 2013 9:06 pm
by KwakKwak
Cheers Ross, the carbs were drained on the bike before removal, the bike was on the side stand now that I think of it, not the paddock stand, don't know if this would explain it - 1 sitting lowest? Floats seemed fine, 110 jets to all four carbs though! Will be fitting 90s to start off with. Having serious problems removing the float filter valves, scared i.m gonna shred them, £60 odd each, pricey, they are stuck with old fuel gunk, sprayed with carb cleaner, wd40, covered pliers, moved them around gently with a screwdriver, but buggered if they will budge, am I missing something? Everything is stripped, cleaned and waiting to go back in, but for these buggers. Got one out, the mesh dome is a little mishapen but not damaged, did you have any of these issues.
Posted: Sat Aug 17, 2013 5:48 pm
by ross46
grip them with some locking pliers round the outside, and the actual filter bits are only £4.50 each, so if there really bad, might just be worth replacing them as they only clip on
Posted: Sat Aug 17, 2013 6:51 pm
by KwakKwak
Got another out, last two are stuck solid, reckon patience and possibly nice shiney new pliers will help, ta for your help.
Posted: Sat Aug 17, 2013 7:05 pm
by ross46
No problem, as I said, this is about setting up the carbs, banners has more information on the side of stripping, that's why I said to use in conjunction
Posted: Sun Aug 18, 2013 9:16 pm
by KwakKwak
All 4 out, it's like almost giving up the ciggies, one a day
Cheers for the help.
Posted: Sun Aug 18, 2013 11:37 pm
by ross46
No problem, though may get the mods to lock this thread after ive perfected it and got my carbs back from banner after being sonicated, then all the seals will be green (maelstrom
Posted: Mon Aug 19, 2013 11:23 am
by banner001
ross46 wrote:No problem, though may get the mods to lock this thread after ive perfected it and got my carbs back from banner after being sonicated, then all the seals will be green (maelstrom
ill strip yours tonight, and get half sonicated tomorrow night, the rest ill sonicate after epic journey...so maybe bank holiday monday if ive recovered sufficiently. dont worry about posting the tyre, i should be off to a mates soon in london, we will do a quick swap carbs for tyre then, probably 1-2 weeks after the bank holiday weekend? - or if thats too late, for you ill post the carbs.
Posted: Mon Aug 19, 2013 11:32 am
by ross46
BANNER! Welcome back, yeah alright, we'll sort something out, I'll redo all the pictures with a better camera, rather than my phone, so any new stuff people want just put
Posted: Mon Aug 19, 2013 11:19 pm
great write up, can i use it to add to the main website?
Posted: Tue Aug 20, 2013 10:14 am
by ross46
Of course, but can you give it a bit as im not 100% happy with it, so can I finish it properly first?
