Page 2 of 2
Re: Strange engine behaviour
Posted: Fri Feb 05, 2016 8:18 pm
by Ewetea
You must use water, because a liquid cannot be compressed (i.e. squeezed into say half it's normal volume, like a gas). When pressure is applied to a liquid it just transfers that pressure to the enclosure, trying to stretch it, albeit by a minute amount (in the bike, it would be the hoses expanding). I vaguely remember that the pressure in the coolant system of an engine is about 10 - 12 psi. Fill your system with water and then pressurize it to 10psi. If there is any leakage anywhere, just a drop of water loss will result in a significant fall, or even complete loss of pressure. If you used air to pressurize the system it would take ages to reduce with a small leak, and you couldn't be sure that the loss was not caused just by a change in temperature.
Posted: Sat Feb 06, 2016 6:50 am
by Bogdan.V
Thank you for advice! I found the details of this operation here (page 6):
http://www.zxrworld.co.uk/Manuals/H%20M ... er%203.pdf
Posted: Sat Feb 20, 2016 8:08 pm
by Bogdan.V
I just hit a dead end. I spent a bit of time trying to check and fix everything on my engine. So far...
- compression: OK
- valve clearance : OK
- spark plugs: OK
- carburetors: REBUILT (striped apart, cleaned, O-rings replaced)
- spark plug cables REPLACED
I decided skip the head gasket test for the moment because the compression and oil (no milky oil) seems fine.
And the engine still runs like crap...
https://www.youtube.com/watch?v=BY7hDy8UC3A
None of the spark plugs are wet or blacked. If I take out the spark plugs cables from #2 and #3 and start the engine it still runs, worse, but it runs. If I take out the cables from #1 and #4 the engine doesn't run at all if I try to start it. I switched the coils between them to rule out a bad coil possibility but no difference. If I take out the cables from each spark plug one at a time, the engine runs worse than with all four cables connected but at the same peace at each cable token out.
What can go wrong?
Posted: Sun Mar 06, 2016 5:47 pm
by Bogdan.V
Could this problem be because of unbalanced carburetors? Poor running is present at idle also at high revs. The carburetors was entirely striped apart (even main bodies one from each other) for cleaning and after that where balanced only visually on the table. I would like to balance them to rule out this problem but I don't have the tool yet. I also suspect that carburetors wasn't clean properly.
Posted: Sun Mar 06, 2016 7:15 pm
by richyrd5
if you think they werent cleaned properly then get them apart again and give them a real good clean out(i have recently had to do this)..ran much better...also they will defitnatly need to be balanced properly with gauges if you have taken all the linkages apart...it will run real bad if there not bananced properly..
Posted: Sun Mar 06, 2016 8:04 pm
by Bogdan.V
Does the unbalancing affect the engine run at high revs too? Shouldn't only affect the idle and low revs?
Posted: Sun Mar 06, 2016 8:24 pm
by richyrd5
if they are out a lot it will affect them yes,,,try cleaning/balance then see how you go
Posted: Sun Mar 06, 2016 8:43 pm
by Bogdan.V
I will balance them and if the problem still persist I will clean them again and come back with results. Thank you!
Posted: Sun Mar 06, 2016 9:05 pm
by richyrd5
no problem..good luck and tells us how you get on,,its frustrating but you will get there in the end
Posted: Wed Mar 09, 2016 7:14 am
by Bogdan.V
By the way, could some possible problems to the alternator affect the engine performance in this way (like described above)? Although I have sparks to all spark plugs, I ask this because of desire to learn.
Posted: Wed Mar 09, 2016 8:13 am
by richyrd5
On some bikes,yes it can.(I have a vfr and the rectifier playing up can cause problems on one of these)but generally..no.but you could as a precaution check the voltage when its running.put lights on and rev to 5000..should be 13.8/14.3 volts across the battery terminals..but I think its more likely carb problems with yours...have you balanced them yet??
Posted: Wed Mar 09, 2016 8:50 am
by Bogdan.V
Not yet. Most probably the carburetors has some clogged air or fuel passes because I think the unbalanced carburetors cannot cause so much vibrations / poor running also on high revs and I don't want to spend money to balance them twice in case that the problem is clogged passes. Tomorrow I will soak the carburetor bodies for an hour in carburetor cleaner and blast the holes with compressed air after that to make sure they are clean. I would prefer an ultrasonic cleaner but I cannot find one in my area. Soaking the bodies in carburetor cleaner seems the best alternative for me. Last time I boiled them in water with lemon juice
but the lemon juice has left some sticky deposits on carburetor bodies. They where cleaned with a cloth and blasted with compressed air only the next day when they where dried so I think there are still some deposits inside air / fuel passes. After tomorrow cleaning I will balance them and see how it goes.
Posted: Sat Mar 12, 2016 7:51 am
by Bogdan.V
The engine runs fine now, at least below 4000 rpm. Most probably the carburetors wasn't clean properly last time. I just find out that my cam chain is loosen and I have to replace it so I didn't want to rev the engine higher. After I replace it I will come with the final results. I think the problem from the start was that my valve clearance where a bit too tighten and that caused the engine to start very hart at cold. Anyway, I learned a lot since then, I also made some little mistakes (but I guess everybody does at the beginning). I could not get this far without the help of this forum so thank you all for your support!
