Page 2 of 9
Posted: Thu Jun 14, 2007 10:49 pm
only on models built for the colder climates.
Posted: Thu Jun 14, 2007 10:52 pm
by SplaTZXR400
lol like the UK model :smt004 yep very cold and wet.
Posted: Thu Jun 14, 2007 10:54 pm
As far as i know just some models, my first ZXR didnt have that heater system but my current one does but it is an import. Yet sean's is a uk bike but doesnt have it :smt012
Re: Does your zxr400 have hot starting problems?
Posted: Tue Jun 19, 2007 3:22 pm
by rene
mine did iirc becasuse i couldent work out why it would be routed to were it was then to the carb lol now it all makes sence!
Posted: Fri Jun 22, 2007 11:39 am
by lindaloo
1993 l3
standard Air filter
No idea on spark plugs
Standard carbs
standard exhaust system
23,000km
No carb heater
No hot starting problems at all :smt001
Posted: Wed Jun 27, 2007 10:05 pm
by sole
1999 l9
33k miles
only thing not standerd art race can
heated carbs
& has hot starting problems
Posted: Thu Jun 28, 2007 8:35 am
by greengoblin
I've always thought it was just a Kawasaki thing. Every one I've owned has been a slow starter when warm. Living in the frozen north means they've all had carb heaters fitted :smt003
L8
standard Air filter
Dyno-jetted carbs 96 Main jets
8,000mls
Carb heaters
Posted: Sun Jul 08, 2007 3:16 pm
by dizzycat
L4
Standard air filter
NGK CR9EK
standard down pipes, blueflame end can
15,000 miles
Never starts when hot! :smt013
Posted: Fri Jul 27, 2007 9:44 am
by spaz
stock L2
42,000km
no carb heaters
no trouble with hot starting
Posted: Tue Aug 07, 2007 2:17 pm
by mike684
'94 SP.
Standard airbox, no filter
Denso Iridium plugs
Beet Co Japan full system
Needle circlip adjusted to 3rd notch from end of main jet needle
No idea about milage - it's a race bike
No cooling fan fitted
Will start from cold no probs. However, when it's hot it is as if the battery is dead - the starter barely turns the engine over. Sometimes all I'll hear is a relay clicking when I thumb the starter button. It will bump start on the 2nd or 3rd attempt though so I'm thinking it's an electrical gremlin in the works somewhere. If I leave it to cool down after a session on track though it will start no probs. Weird......
Posted: Tue Aug 07, 2007 2:20 pm
Sounds a bit like your battery is on its way out to me, cos the relay usually only clicks like that when the battery is going flat, could be its being charged incorrectly causing it to get hot.
Posted: Thu Aug 09, 2007 4:18 am
by emperorluigi
1991 L1
Standard air filter
Don't know about plugs
Standard carbs
Standard exhaust
37,000 miles
Not sure on carb heaters, I'll check later.
No starting problems at all. Starts easier when it's hot :smt101
Posted: Thu Aug 09, 2007 7:10 am
Just a thought here, zimm was saying in another thread about different cams etc being in the engines, could this be a related issue?.
Posted: Thu Aug 16, 2007 2:47 pm
by sic1181
Can i just try n put my view on this, my mate jon who owns his own bike shop n has previously owned and ridden lots of zxr 400s, i had this problem myself a while ago. He told me its somethin to do with the engine thermo playin up. Then 3 months later my head blew cos my engine thermo had died (common fault apparntly). Dont wanna say this is definately the cause behind everybodys problems but i wud get the thermo checked out just incase.
Posted: Thu Aug 16, 2007 2:50 pm
are you talking thermostat??
