Hello, im due to replace the front discs on my bike, one is warped and both are at 2.8mm ish!
Anyone rate these chinese discs on ebay,
http://cgi.ebay.co.uk/Front-Brake-Disc- ... 35ac2eec34
or
http://cgi.ebay.co.uk/Front-Brake-Rotor ... 1c14d39e37
the thickness of them is 5 and it states min thickness of 4.5mm, both of which are above standard discs, good or bad? either showing that these might be suspectible to warping after little use.
Also as you will see the first set it more 'hollowed' whereas the second set is clearly different, im a bit unsure of the correct terms to describe the discs!
Cheers Ross
ZXR400 front discs, opinion required
ross01505
what would life be without bikes!
ZXR400 l4
GSXR Shock
CBR954 Calipers
ZX7R Master Cylinder
Full Micron Sys
Custom Quickshifter
Braided Lines
Skimmed Head
Camera Mount - Yeeha!
ZXR400 l4
GSXR Shock
CBR954 Calipers
Full Micron Sys
Custom Quickshifter
Braided Lines
Skimmed Head
Re: ZXR400 front discs, opinion required
They don't specify a brand from what I can see so dont know. They look to be what one or two ppl here have bought before, I think those were made by a firm called kagizume (sp)?
