hello guys,
my engine dropped a valve the other day and i cant decide what to do with it.
is it worth replacing the damaged valves, inlet camshaft, oil gallery, piston, rockers, etc...
or is it cheaper to just fit a second hand engine?
dying out its butt
razzcolio
- My Bike: ZXR400L1/VT750C2B/VT600
Re: dying out its butt
Would probably be cheaper and definately easier to get 2nd hand motor, and use your broken motor for spares?
- Tirpitz
- My Bike: Kawasaki ZXR400L4
Only concern with fitting a second hand motor is that if you're keeping the bike as an investment hoping that it will be a future classic then if the engine and frame numbers don't match as original you can forget it. A restorer in future can sort a tatty original bike back to concours condition. If the original motor has gone there's nothing gonna bring that back. Depends what you want the bike for - to ride or as an investment. Then again, money it's going to cost to sort that motor will mean you'd never get the value back again no matter how much it appreciated, especially as you can't do the work yourself.
Hel braided hoses
Pirelli Diablos
Ohlins steering damper
A16 carbon fibre exhaust can
Nitron Sport shock
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
with a 2nd hand motor you might just be ending up buying more problems - you already know what your engine needs.
Until conrods go smashing through casings nothing is really that terminal although melting a head does make it pretty fubar too.
As Tirpitz says, what's the bike going to be doing ?
Price up the parts with the online fiche I've posted then see what used motors cost and factor in you might still need to service it too or even do a head gasket!
