Worn Cams From Knee Down
Posted: Mon Jul 02, 2012 5:30 pm
by mikeee
Hi
Soo according to the garage i take my bike to have have worn cams on the left hand side (piston 1/2), the guy says that this is most likely occured from that side being starved of oil, so i asked him if getting my knee down a lot on the right hand side could cause this, and he said it's most likely, yes. just thought i'd share this, as its a new one to me, maybe its not true, i dunno.
Mike
Re: Worn Cams From Knee Down
Posted: Mon Jul 02, 2012 5:38 pm
by CaNsA
Could be a blocked oil feed......
Posted: Mon Jul 02, 2012 6:42 pm
by mikeee
possibly, well its booked in wednesday, as replacing cams is past my limited expertise. hopefully they'll sort it out and check the oil lines, having the carbs balanced aswell
Posted: Mon Jul 02, 2012 7:04 pm
by bendog66
could also be not warming it up enough
Posted: Mon Jul 02, 2012 7:06 pm
by mikeee
again, possibly, although i do try to warm my bike up before i set off and keep the revs low for a bit, but then if it was due to not warming it up, would it not be that all the cams were worn not just piston 1/2??
Posted: Mon Jul 02, 2012 8:54 pm
by bendog66
oil flow goes from right to left so you're more likely to get it where you've got it
Posted: Mon Jul 02, 2012 10:22 pm
by mikeee
hmmmm, makes sense. just changed the oil and filter, and there was a lot, and i mean a lot of metal bits in it :S
Posted: Mon Jul 02, 2012 10:51 pm
by CaNsA
mikeee wrote:well its booked in wednesday
Oh snap girlfriend!
So is mine
Posted: Tue Jul 03, 2012 3:20 am
bendog66 wrote:oil flow goes from right to left so you're more likely to get it where you've got it
Good post I think now take your thoughts to a logical conclusion
Posted: Tue Jul 03, 2012 7:45 pm
by mikeee
CaNsA wrote:mikeee wrote:well its booked in wednesday
Oh snap girlfriend!
So is mine
What's up with yours then CaNsA?
Posted: Tue Jul 10, 2012 11:19 am
by Tirpitz
mikeee wrote:Hi
Mike
I'd be finding another garage. So he reckons that a motorcycle engine, which is designed to function properly at various inclinations to the horizontal whilst cornering (no rider on earth ever went round a corner with a bike bolt upright!), has chewed its cams because it has been run whilst inclined at a normal angle.
The bloke's either a complete tosser or a rip-off merchant.
Posted: Tue Jul 10, 2012 1:43 pm
by mikeee
i only mentioned this as, on a wednesday night we go down to a local roundabout which has a nice surface and isn't busy at all, be it a roundabout, i only go down on the right hand side and have been doing so for a few months, it was just a suggestion, probability is my oil pump is on its way out or so.
