Make gaskets at home
Posted: Fri Feb 05, 2016 10:16 pm
by Rubencio
Would like to buy some gasket material to make my own gaskets for the cluck cover and such.
In eBay there are plenty of sheets for just few quid.
Can't decide how thick the material has to be, any suggestion?
Re: Make gaskets at home
Posted: Sat Feb 06, 2016 9:40 am
by Dominik
I'd rather suggest liquid gasket like black seal or so. I used this on left hand cover and Kawasaki uses it for the engine halfs. Also newer bikes have this for normal engine covers...
Posted: Sat Feb 06, 2016 9:54 am
by Tricky
as above, i also use liquid gasket sealer, just a light smear on one face.
Posted: Sat Feb 06, 2016 10:02 am
by Ewetea
The big problem I have found with making gaskets is the holes. Ideally a hollow punch is needed to obtain a nice round hole. To make a punch, a piece of tube is required which can then be ground or filed to give a sharp edge on the diameter. But unless it is a hardened material, it will quickly blunt and just crush the material instead of cutting it. I used a modelling knife with a scalpel blade, but if the material is thick, it is very tricky to apply pressure and turn in a circle - the holes looked more like hexagons. For the effort involved it could be a lot quicker to just buy one. Someone on the forum did organize the fabrication of various gaskets which were sold to members at a reasonable price, and in fact I purchased clutch/alternator/pulse cover gaskets which were quality items.
Posted: Mon Feb 08, 2016 12:41 pm
by banner001
yes that was ross46, but he has been quiet for a while.
i have access to a waterjet (for free) so if i can get hold of his cad drawings, or if someone wants to make some and send them to me i can get them cut and posted for pretty much cost price (sheets plus postage)...ill check with the operator, but im sure it will do gaskets...
Posted: Mon Feb 08, 2016 9:40 pm
by richyrd5
Yes.id be up for genny.pulse.and clutch gaskets...
Posted: Sat Feb 27, 2016 10:57 am
by richyrd5
I have sorted Genny and pulsar ones now...but if its cheaper to get a clutch cover one from your good self I would be up for that...
Posted: Fri Apr 08, 2016 11:35 am
by 400y
Ewetea wrote:The big problem I have found with making gaskets is the holes. Ideally a hollow punch is needed to obtain a nice round hole. To make a punch, a piece of tube is required which can then be ground or filed to give a sharp edge on the diameter. But unless it is a hardened material, it will quickly blunt and just crush the material instead of cutting it. I used a modelling knife with a scalpel blade, but if the material is thick, it is very tricky to apply pressure and turn in a circle - the holes looked more like hexagons. For the effort involved it could be a lot quicker to just buy one. Someone on the forum did organize the fabrication of various gaskets which were sold to members at a reasonable price, and in fact I purchased clutch/alternator/pulse cover gaskets which were quality items.
To cut the holes you can use a paper punch (the holes are first marked from an original gasket). Take the back off said punch that collects the bits. Slide gasket in and you can see the hole marks on the gasket. Just nibble around the marks - simples.
