Indicators packed up
Posted: Sun May 07, 2006 10:04 pm
by crashtester01
coming home from work and my indicators packed up not a big prob i no but im as technicaly minded as a fish and i aint got a clue where the flash unit thing is can eny 1 tell me
Posted: Mon May 08, 2006 9:11 am
bloody hell this brings back memories, coming back from minehead up the M5 the bloody indicators kept packing up, if i remember right the flasher unit is on the right hand side under the main seat, you will probably find a loose connection there.
Posted: Mon May 08, 2006 1:11 pm
by crashtester01
cheers but no luck as i dont no what the bloody thing looks like checked all the conections I could find but still no luckalso noticed that the solanoied (think thats what its called eny way silver thing on the left hand side with a fuse in it
) is a bit nackered its plastered in tape and the fuse is glued in god only nos why think its time for me and the zxr to part company before it robs me of evan more cash
Posted: Mon May 08, 2006 1:18 pm
there should be a flasher unit on the right hand side, its a cube with 2 wires going into it, mine kept coming apart so wrapped it in tape, that's whats wrong mate or the flasher has gone.
Posted: Mon May 08, 2006 3:57 pm
by Bikerz
Im the expert on flasher units
its on the right side under seat, take fairing off on the rear , ur see a black box about 4cm by 2 cm cliped onto the frame with 2 wires going into it, that ur flasher unit, i just recently canged mine for a LED one, if u cant find it turn ur indicator on and u should be able to hear it click (if ur in a quite place) let me knoe how you get one
Sheldon
Posted: Tue May 09, 2006 4:55 pm
by crashtester01
pickeed up a new flasher unit it worked for about 2 seconds and then it stopped again so i think i got a wiring problem some where :smt013 thanks for your help guys
Posted: Tue May 09, 2006 7:07 pm
by Bikerz
if u need a new flasher unit mate, if u broken yours then u can have my stock one as i dont need it
Posted: Thu May 11, 2006 6:50 pm
by crashtester01
cheers m8 but i think it will just go again the bike is off to an auto electrishan on friday to have the wiring looked at but thanks for that m8
Posted: Mon May 15, 2006 12:15 pm
by crashtester01
£200
later i now have a repaired wiring loom working indcators and a have tidy solanoide at last and i bet the guy fixed it in about half an hour
Posted: Tue May 16, 2006 10:10 pm
by mongo
unfortuantely the looms do suffer from getting water in them if they are left outside/used in all weathers.
very common especially where it branches off at the clutch and at the radiator.
Sounded like it was an earthing problem to me though, oh well at least its up and running again!
Posted: Thu May 18, 2006 12:53 pm
by Xphyral
I replaced all the block plug pins on my loom when i got my bike. The electrics would cut out whenever i turned left. After removing tank and airbox had a look at the block coming from the barrel and all the pins in it were pretty much corroded to dust. Just got an electrical crimper set from B&Q and went and replaced everything on the bike. So if you get an old zxr and your having electrical probs check all your block plugs for corrosion, their very easy to replace and only costs you 20 quid and a little time
