ZXR 400 Rough below 5-6k boggy + backfire any ideas?
Posted: Mon Jun 19, 2017 7:46 pm
by reggie1324
Hi All just new to ZXR'S and this forum :)
So I have bought a ZXR 400 L9 with 531 miles on the clock, It has been sitting in the showroom of a racepaint company for 16 years and hasn't been ridden in that time.
So about me, I do most jobs on my bikes the only thing i won't touch is gearboxes :)
The last carb bike I had was a Honda Nc29 years ago.
So far I have
cleaned inside of the tank
cleaned carbs ( air compressor and brake cleaner )
set idle to 2.5 turns out ( same as it was )
new plugs
new oil
new coolant
new air filter
The bike struggles up until about 5-6k then comes to life, and if you take it to redline it with backfire.
Now im not familiar with these bikes atall so if there any common symptoms I have mentioned? If so any help would be much appreciated.
Thanks all
Reggie
Re: ZXR 400 Rough below 5-6k boggy + backfire any ideas?
Posted: Mon Jun 19, 2017 7:52 pm
by reggie1324
to add to this sorry
I can't seem to get the choke to work properly, if I put it full on the bike will cut out.
Also sometimes the revs will hang around 2.5k then drop back down
Posted: Tue Jun 20, 2017 12:28 am
by bendog66
When you say set idle do you mean the idle mixture screws?
If so, the original settings for these were 1.75 turns out so try that and see if it helps
Posted: Wed Jun 21, 2017 8:42 am
by reggie1324
:smt010 LP
bendog66 wrote: Tue Jun 20, 2017 12:28 am When you say set idle do you mean the idle mixture screws?
Thanks will give that ago. If that don't work I will have to have the carbs off again I think and double check​ everything
Posted: Wed Jun 21, 2017 7:17 pm
by reggie1324
Tried 1.75turns still the same. It's almost like it's running on 3 untill 6k+rpm
You guys think carbs or coils?
Posted: Wed Jun 21, 2017 10:38 pm
by bendog66
Blocked pilot jet?
Posted: Thu Jun 22, 2017 7:33 pm
by reggie1324
bendog66 wrote: Wed Jun 21, 2017 10:38 pm Blocked pilot jet?
so nearly sorted it :excited
These carbs have been sitting so long I think the o rings on the pilot screws are done.
Also a pilot screw is bent as well as a needle having bad corrosion.
Where is the best place to buy rebuild kits and jets etc?
Thanks guys
Posted: Thu Jun 22, 2017 9:42 pm
by Miles
I would say your carb o-rings have dried out from lack of use.
I'd recommend a seal kit from lite tek and new needles from kwak
Posted: Thu Jun 22, 2017 10:32 pm
by reggie1324
Miles wrote: Thu Jun 22, 2017 9:42 pm I would say your carb o-rings have dried out from lack of use.
Thanks just ordered the kit from lite tek, bike is rideable atm so will go and enjoy it while I wait for its parts to come biggrin
