Wet/oily spark plugs?
Posted: Mon Aug 28, 2017 2:25 pm
by Smokingviper1
Just bought a zxr 400 L6 from a mate and it runs sweet as a nut, but there is a mysterious oil leak on front if the engine which seems to wet the while front.
We took tank of to get to the plugs, and when pulling thsm out to check them they were all wet with im guessing oil.
that meant to happen? Or if not can someine offer a solution? Bike not on road yet but about to finish my test
Re: Wet/oily spark plugs?
Posted: Mon Aug 28, 2017 4:20 pm
by bendog66
Check the seals between the rocker cover and the spark plug wells. There's a drain hole for each spark plug well that's on the front of the engine below the headers
Posted: Mon Aug 28, 2017 5:50 pm
by banner001
As per what bendog said, there are 2 seals per spark plug tube, one between the rocker cover and the removable spark plug tube, and an o ring around the spark plug tube where it seals to the head.
You might want to err on the side of caution and replace the rocker cover gasket at the same time.
Posted: Wed Aug 30, 2017 12:20 pm
by Smokingviper1
banner001 wrote: Mon Aug 28, 2017 5:50 pm As per what bendog said, there are 2 seals per spark plug tube, one between the rocker cover and the removable spark plug tube, and an o ring around the spark plug tube where it seals to the head.
So on removing the rocker cover i can easily get to seals? Wheres thr best placr to get them?
Posted: Wed Aug 30, 2017 12:21 pm
by Smokingviper1
So it aint leaking oil as such just draining oil that shouldny be there?
Posted: Wed Aug 30, 2017 9:03 pm
by banner001
cradley kawasaki (http://www.kawasakioriginalparts.com/ro ... country=gb)
you need:
11009-1733 if oil is getting between the rocker cover and spark plug tunnel
92055-1403 if oil is getting between the spark plug tunnel and the cylinder head
11009-1732 if oil is leaking around the rocker cover
Posted: Thu Aug 31, 2017 4:12 am
by Mori Man
banner001 wrote: Mon Aug 28, 2017 5:50 pm You might want to err on the side of caution and replace the rocker cover gasket at the same time.
If your removing the rocker cover for any job , order a new gasket ( unless it's been changed recently ) as it has now been revised and gives a better seal.
:smt001
Posted: Wed Sep 27, 2017 10:13 pm
by Smokingviper1
All fixed 👌👌
Posted: Thu Sep 28, 2017 9:27 am
by banner001
excellent, which gaskets/oil seals did you change in the end?
Posted: Sat Dec 02, 2017 2:31 am
by Smokingviper1
banner001 wrote: Thu Sep 28, 2017 9:27 am excellent, which gaskets/oil seals did you change in the end?
Sorry for long reply mate, basically qll of them 😂 main gasket, the o-rings and the washers, they were all as hard and stiff as plastic... defo needed a change
Posted: Sun Dec 03, 2017 12:38 pm
by banner001
For the minimal cost, and lifetime of the seals, it's a bit of a no brainer unless your proper skint at the time
