Help! front brakes
Posted: Wed May 18, 2005 11:59 am
by Leanne_
hey everyone,
i have an L1 model and recently noticed the front brakes has gone off badly the lever travels right back to the handle bars with very little effect! the seals in the calipers have been replaced and the brake pads are fine so im not sure what else it could be? theres goodridge hoses on the bike so might they have stretched? i know theres no air in the system as the brake doesnt pump up,
any help would be much appreciated
thankyou
Leanne
Posted: Wed May 18, 2005 5:52 pm
by Jamz
Are they metal braided brake lines on it?
If so, as far as i know they don't 'go off' or stretch.
If you haven't got metal ones, looks like you're gonna have to get some!!! It's well worth putting some on, anyway.
For a quick (possible) fix, take the lid off the reservoir and then pull the brake lever as far back to the bars as it will go, then clamp it there with some lock-ties or something similar. Simply leave it like this overnight, then untie it, and you SHOULD get better brakes!!! :D
It's best to leave the top over the reservoir when you've unscrewed it, just to stop any crap dropping into it overnight.
Good luck!!! :D
Posted: Wed May 18, 2005 6:14 pm
Piston in the master cylinder could have had it, in which case it would give you some braking effort but not as much as what it could. Does the lever come back to the bar when its standing still?? If it does it probably is the master cylinder.
Posted: Wed May 18, 2005 8:03 pm
by Guest
yeh they are metal ones,
thanks for the suggestion i have tried this before but had no luck :(
yeh it does come back to the bar when its standing still, are the master cylinders expensive/hard to replace do you know?
thankyou for the help
Leanne
Posted: Wed May 18, 2005 8:38 pm
by techie
Should be able to pick a good one up from a breaker alright. Not too sure what sort of price.
make sure that the bango bolts are clean and the washers are in good nick when you replace the cylinder, it really is an easy bolt on replacement and a plug for the front brake switch.
Before spending money on it though, read the manuals from my web site and strip the master cylinder to confirm fault.
http://wwr.dyndns.org
Posted: Wed May 18, 2005 11:08 pm
by fever
i have the same problem leanne...notice it takes ages to bleed the system?
ive changed the m/cylinder piston,spring and seals (£17.99 m&P) and completely o/hauled the calipers...no joy :(
i reckon its the spliter...so im changing the hoses for a completely different set up.
Posted: Thu May 19, 2005 11:28 am
by Guest
yeh it takes ages for mine to i know there no air in them, i payed £68 to replace the seals in the caliper still no joy so i might try what you have done, thanks for letting me know you can get it from m&p, what are you going to change the hoses to?are u running goodridge braided hoses now?
thanks for the help guys
Leanne
Posted: Thu May 19, 2005 6:21 pm
fever wrote:i have the same problem leanne...notice it takes ages to bleed the system?
Why would it be the splitter?
If you do go for braided hoses just go for a two line set-up on the front.
Posted: Thu May 19, 2005 6:34 pm
by sloweracing
Good luck please let me know how you get on Leanne
Posted: Thu May 19, 2005 10:59 pm
by fever
RobB wrote: Why would it be the splitter?
the splitter is the only thing i havnt changed in the brake system..if you look inside one you'll see theres a small recess which could harbor tiny air bubbles.
Posted: Fri May 20, 2005 2:05 pm
by Guest
sloweracing wrote:Good luck please let me know how you get on Leanne
i will do thankyou for your advice and i will let you know asap
thanks again
Leanne
Posted: Fri May 20, 2005 5:01 pm
Ahh rite i see, wouldnt it be an idea to undo the splitter from the yoke and move it to a position where the air is likely to move into the fluid flow??
Posted: Fri May 20, 2005 5:47 pm
by fever
we'll find out tomorrow...if this works i will be sending you big hugs...but no kisses thou :wink: hehe
Posted: Fri May 20, 2005 9:03 pm
lol, no probs.
Dont worry im not worried about not getting any kisses :lol:
