cam chain rattle
kion
- My Bike: zxr400
cam chain rattle
Think i have cam chain rattle???
http://media.putfile.com/video-0006-15
How long before the chain falls off??
ride with pride
Re: cam chain rattle
depends wether you start your bike again or not
who knows mate, like i say how hard its ridden, how long you use it for?, how worn is the chain?
kion
- My Bike: zxr400
not sure how worn the chain is, just gonna g shop today and get my new gear then leave it. Gona replace the chain and tensioner and mit aswell do the head gasket. Is it possible to replace the chain with just the cylider head of?
ride with pride
read this mate viewtopic.php?f=7&t=4383
kion
- My Bike: zxr400
cheers master, not even sure if it is the cam chain rattlig, hard to tell. Silences a bit when i ul he clutch n.
ride with pride
if you pull the clutch in and it disappears its the old clutch noise, if it only goes away a bit then i would imagine its both your clutch and cam chain.process of elimination methinks.
muffinman
sounds like both
camchain and headgasket are easy to change anyway
mingmingmo
- My Bike: ZXR400
last year after the nec my cam chain went and had to travel about 50ish miles. manged to get it back thankjfully but when i got over 5 - 7k revs then the noise went away. took the cam chaijn out and didnt really look worn but once replcaced then it was fine so sumtimes the noise does disapear. dont take too long untill u repolace it otherwise it can blow .
donbt think this helps at all but hey there u go lol
Mingmingmo
Sorry officer i thought you wanted a race .
kion
- My Bike: zxr400
i can only hear mine at idle, when i put my ear next to the engine, maybe because i have a loud exhaust.
on my drz the head gasket took days to replace, will i have to check valve clearance aswell?
anyone know where i can buy a cam chain and guides, maybe headgasket?
ride with pride
Have a listen to mine, i got a close up of the engine so maybe have a listen? They are all a bit rattly thats part and parcel of the ZXR.
http://www.youtube.com/watch?v=oc_AawMkJR4
kion
- My Bike: zxr400
kion
- My Bike: zxr400
ye there seems to be a rattle but only at idle, i red in another thread that this is the cam chain tensioner that needs adjusting???
ride with pride
